- 0
Updated Powershell script with June 2015 drivers for deploying the Surface Pro 3 with MDT 2013
Asked by
Asked by
On June 25th, Microsoft released another driver update for the Surface Pro 3 here. As usual, i've updated my PowerShell script to allow you to deploy this awesome device using minimal effort via a MDT 2013 solution all built with PowerShell.
I've updated the script somewhat to include a few more variables to allow for easily changing the source drivers going forward, to change them simply input the correct values for the following variables:
You don't need to change this script now however, just download it, and run it on a Windows Server 2012 R2 in Windows PowerShell ISE as administrator, the script will do the rest.
If you want to know how the script works then please see this post for more details. When the script is finished running it should look like this.
you can review the installation of MDT 2013 which it has created for you complete with all the June 2015 drivers for the Surface Pro 3 by opening up the Deployment Workbench and seeing for yourself.
which means you can PXE boot a Surface Pro 3 straight away and start imaging it
The actual driver updates are listed below
FIRMWARE:
EC 38.7.50.0 ECFirmware.inf
SAM 3.9.350.0 SamFirmware.inf
TOUCH 426.27.66.0 TouchFirmware.inf
UEFI 3.11.950.0 UEFI.inf
DRIVERS:
Accessory SurfaceAccessoryDevice 2.0.1012.0 SurfaceAccessoryDevice.inf
Accessory SurfaceCoverAudio 2.0.722.0 SurfaceCoverAudio.inf
Accessory SurfaceCoverClick 2.0.375.0 SurfaceCoverClick.inf
Accessory SurfaceCoverTelemetry 2.0.722.0 SurfaceCoverTelemetry.inf
Accessory SurfaceTouchCover 2.0.722.0 SurfaceTouchCover.inf
Accessory SurfaceTouchCover2FwUpdate 2.0.722.0 SurfaceTouchCover2FwUpdate.inf
Accessory SurfaceTouchCoverFwUpdate 2.0.722.0 SurfaceTouchCoverFwUpdate.inf
Accessory SurfaceTypeCover 2.0.1193.0 SurfaceTypeCover.inf
Accessory SurfaceTypeCover2FwUpdate 2.0.722.0 SurfaceTypeCover2FwUpdate.inf
Accessory SurfaceTypeCoverFwUpdate 2.0.722.0 SurfaceTypeCoverFwUpdate.inf
Accessory SurfaceTypeCoverV3FwUpdate 2.0.1021.0 SurfaceTypeCoverV3FwUpdate.inf
Accessory SurfaceWirelessAdapter 1.0.1.0 SurfaceWirelessAdapter.inf
Audio DockingStationAudioDevice 1.31.35.7 msdokub.inf
Audio HdAudio 6.0.1.7198 HDXMSSDS1.inf
Camera LifeCam 5.20.1034.0 TrueColor.inf
Display DisplayAudio 6.16.00.3172 IntcDAud.inf
Display Graphics 10.18.14.4170 64dp4170.inf
Display SurfaceDisplayCalibration 2.0.1002.0 SurfaceDisplayCalibration.inf
Network Bluetooth 15.68.3091.193 mbtr8897w81x64.inf
Network SurfaceEthernetAdapter 8.10.0830.2013 msu64w8.inf
Network SurfaceGigabitEthernetAdapter 8.14.0704.2014 msu30x64w8.inf
Network WiFi 15.68.3091.193 mrvlpcie8897.inf
Pen SurfacePen 1.0.13.0 SurfacePen.inf
Pen SurfacePenSettingsDriver 4.0.112.1 SurfacePenDriver.inf
System CapacitiveHomeButton 2.0.1179.0 SurfaceCapacitiveHomeButton.inf
System CardReader 6.2.9200.30164 RtsUStor.inf
System GPIO 1.1.165.1 iaLPSS_GPIO.inf
System I2C 1.1.165.1 iaLPSS_I2C.inf
System LowPinCount 9.4.0.1023 LxLpCore.inf
System ManagementEngine 9.5.24.1790 heci.inf
System SATA_AHCI 9.4.0.1023 LxLpAHCI.inf
System SMBus 9.4.0.1023 LxLpSMB.inf
System SurfaceIntegrationDriver 2.0.1182.0 SurfaceIntegrationDriver.inf
System SurfacePciController 2.0.1151.0 SurfacePciController.inf
Download the script
Here's the script, download it, unzip, run it in Windows PowerShell ISE.
Setup MDT 2013 for Microsoft Surface Pro 3 - June 2015.zipFetching info...
enjoy !
niall
