razorblack Posted July 1, 2015 Report post Posted July 1, 2015 Hello Guys!! I'm wonderinf if some of you could help me out with ConfigManager site publishing for internet facing. our site server is configure to use HTTPS only with a working PKI. Site role and ccm clients are all runing very well on the internal. The site system has an externat FQDN configured and that FQDN is published on the internet. DNS entries seem good as well. Is there a tutorial or documentation on publishing my site for internet clients using TMG 2010 or F5? If some of you could helps, i would appreciate a lot Quote Share this post Link to post Share on other sites More sharing options...
0 sacridge Posted July 16, 2015 Report post Posted July 16, 2015 Hey razorblack, You might want to check out these links: https://technet.microsoft.com/en-us/library/cc707697.aspx http://blogs.msdn.com/b/ameltzer/archive/2008/02/14/firewalls-and-internet-based-client-management-part-2-isa-bridging.aspx http://blogs.technet.com/b/jchalfant/archive/2015/04/15/prerequisites-for-ibcm-in-configuration-manager.aspx Good luck and let me know if you get it working! Quote Share this post Link to post Share on other sites More sharing options...
Hello Guys!!
