JazYO.o
SCCM 2012 R2 and MBAM 2.5 Integration Hw Inventory Problem
Hello Everyone. I am trying to integrate SCCM 2012 R2 with MBAM 2.5
But I have problem with importing BitLocker Policy (Win32Reg_MBAMPolicy)
When I run mofcomp against sms_def.mof
C:\Users\scwi\Desktop>mofcomp mbam.mof
Microsoft ® MOF Compiler Version 6.3.9600.16384
Copyright © Microsoft Corp. 1997-2006. All rights reserved.
Parsing MOF file: mbam.mof
MOF file has been successfully parsed
Storing data in the repository...
An error occurred while creating object 2 defined on lines 10 - 42:
0X80041002 Class, instance, or property 'SMS_Class_Template' was not found.
Compiler returned error 0x80041002
Ok so I queried my WMI and I do have that class. It has to be there since I successfully importerd BitLocker Encryption Details (Win32_BitLockerEncryptionDetails)
all the MOF files I got I have from MS websites below.
https://technet.microsoft.com/en-us/library/dn645321.aspx
https://technet.microsoft.com/en-us/library/dn656927.aspx
I was able to import
- Computer System Ex
- Operating System Ex
- Win32_BitLockerEncryptionDetails)
when I removed this portion from the script:
#pragma namespace ("\\\\.\\root\\cimv2\\SMS")
#pragma deleteclass("Win32Reg_MBAMPolicy", NOFAIL)
[ SMS_Report(TRUE),
SMS_Group_Name("BitLocker Policy"),
SMS_Class_ID("MICROSOFT|MBAM_POLICY|1.0")]
Class Win32Reg_MBAMPolicy: SMS_Class_Template
[sMS_Report(TRUE),key]
string KeyName;
//General encryption requirements
[sMS_Report(TRUE)]
UInt32 OsDriveEncryption;
[ SMS_Report (TRUE) ]
UInt32 FixedDataDriveEncryption;
UInt32 EncryptionMethod;
//Required protectors properties
UInt32 OsDriveProtector;
UInt32 FixedDataDriveAutoUnlock;
UInt32 FixedDataDrivePassphrase;
//MBAM Agent fields
//Policy not enforced (0), enforced (1), pending user exemption request (2) or exempted user (3)
[sMS_Report(TRUE)]
Uint32 MBAMPolicyEnforced;
[sMS_Report(TRUE)]
string LastConsoleUser;
//Date of the exemption request of the last logged on user,
//or the first date the exemption was granted to him on this machine.
[sMS_Report(TRUE)]
datetime UserExemptionDate;
//Errors encountered by MBAM agent.
UInt32 MBAMMachineError;
string EncodedComputerName;
I tried to integrate MBAM and sccm but I am getting this error :
Unexpected Configurator error.
Description:
Exception thrown from feature provider.
Exception:
System.NullReferenceException: Object reference not set to an instance of an object.
at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlResultObjectBase.get_Item(String name)
at Microsoft.Mbam.Setup.Common.CmIntegration.SmsEntities.SmsCollection.get_CollectionId()
at Microsoft.Mbam.Setup.Common.CmIntegration.Implementors.CmObjectsManager.TryDeleteInvalidCollection(ISmsCollection collection)
at Microsoft.Mbam.Setup.Common.CmIntegration.Implementors.CmObjectsManager.CreateAndInitializeCollection[T,U](T collectionSettings, Boolean& updated, ISmsCollection& collectionBeforeUpdate)
at Microsoft.Mbam.Setup.Common.CmIntegration.Implementors.CmObjectsManager.CreateCollection(String collectionSettingsFilePath, CultureInfo desiredCulture, CMVersion cmVersion, Boolean& updated, ISmsCollection& collectionBeforeUpdate)
at Microsoft.Mbam.Setup.Common.CmIntegration.CMObjects.CreateCmCollections()
at Microsoft.Mbam.Setup.Common.ActionItem.Run()
at Microsoft.Mbam.Setup.Common.ActionItemQueue.Run()
at Microsoft.Mbam.Setup.Common.CmIntegration.CmIntegrationProvider.Enable(IProgress`1 progress, CancellationToken cancellationToken, CmIntegrationConfiguration configuration)
at Microsoft.Mbam.Setup.Common.FeatureProviderBase`1.<>c__DisplayClass34`1.<InvokeAsync>b__33()
at System.Threading.Tasks.Task`1.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Microsoft.Mbam.Setup.Common.FeatureProviderBase`1.<InvokeAsync>d__36`1.MoveNext()
at Microsoft.Mbam.Setup.Common.FeatureProviderBase`1.<>c__DisplayClass2.<<EnableAsync>b__0>d__4.MoveNext()
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult()
at Microsoft.Mbam.Setup.Common.FeatureProviderBase`1.<EnableAsync>d__8.MoveNext()
at Microsoft.Mbam.Setup.Configurator.CMUIFeatureModel.<EnableTransacted>d__4.MoveNext()
at Microsoft.Mbam.Setup.Configurator.BatchTaskModel.<>c__DisplayClass5.<<Commit>b__1>d__7.MoveNext()
I am assuming it is because I don't have BitLocker Policy imported to my default client inventory because MBAM 2.5 Integration wizard creates device collection MBAM managed devices .
It feels like I tried everything but I know I don't so I decided to ask all the generous people to help me here.
3 answers to this question
why are you running mofcomp on it, have you seen the instructions here ?\
and
these are two SEPARATE mof files, and that's important, one you append to your mof file in <CMInstallLocation>\Inboxes\clifiles.src\hinv\
and the other you import to your clients via default client settings,
so, have you done that ?
I did. This is my config.mof in C:\Program Files\Microsoft Configuration Manager\inboxes\clifiles.src\hinv
// Configuration.mof - WMI configuration that will be compiled on
// SMS clients.
// Copyright © Microsoft Corporation, All Rights Reserved
// Define registry classes for inventory reporting
// - Registry key/value class definition should be done in cimv2,
// - SMS class definition should be done in cimv2\\sms
// Add Remove Programs
#pragma namespace ("\\\\.\\root\\cimv2")
[ dynamic,
provider("RegProv"),
ClassContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows\\CurrentVersion\\Uninstall")
class Win32Reg_AddRemovePrograms
[key]
string ProdID;
[PropertyContext("DisplayName")]
string DisplayName;
[PropertyContext("InstallDate")]
string InstallDate;
[PropertyContext("Publisher") ]
string Publisher;
[PropertyContext("DisplayVersion")]
string Version;
[ dynamic,
class Win32Reg_AddRemovePrograms64
[key]
string ProdID;
string DisplayName;
string InstallDate;
string Publisher;
string Version;
// Virtual PC
[DYNPROPS]
class Win32Reg_SMSGuestVirtualMachine
[key]
string InstanceKey;
string PhysicalHostName;
string PhysicalHostNameFullyQualified;
[DYNPROPS]
instance of Win32Reg_SMSGuestVirtualMachine
InstanceKey = "VPCKey";
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Virtual Machine\\Guest\\Parameters|PhysicalHostName"),
Dynamic, Provider("RegPropProv")]
PhysicalHostName;
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Virtual Machine\\Guest\\Parameters|PhysicalHostNameFullyQualified"),
[DYNPROPS]
class Win32Reg_SMSGuestVirtualMachine64
[key]
string InstanceKey;
[DYNPROPS]
instance of Win32Reg_SMSGuestVirtualMachine64
PhysicalHostName;
// Advanced Client Ports
#pragma deleteclass("Win32Reg_SMSAdvancedClientPorts", NOFAIL)
[DYNPROPS]
class Win32Reg_SMSAdvancedClientPorts
[key]
string InstanceKey;
uint32 PortName;
uint32 HttpsPortName;
[DYNPROPS]
instance of Win32Reg_SMSAdvancedClientPorts
InstanceKey = "SMSPortKey";
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\CCM|HttpPort"),
PortName;
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\CCM|HttpsPort"),
HttpsPortName;
// Advanced Client SSL Security COnfigurations
#pragma deleteclass("Win32Reg_SMSAdvancedClientSSLConfiguration", NOFAIL)
[DYNPROPS]
class Win32Reg_SMSAdvancedClientSSLConfiguration
[key]
string InstanceKey;
uint32 HttpsStateFlags;
string CertificateStore;
string CertificateSelectionCriteria;
string InternetMPHostName;
uint32 SelectFirstCertificate;
uint32 ClientAlwaysOnInternet;
[DYNPROPS]
instance of Win32Reg_SMSAdvancedClientSSLConfiguration
InstanceKey = "SMSSSLConfiguration";
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\CCM|HttpsState"),
HttpsStateFlags;
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\CCM\\Security|Certificate Store"),
CertificateStore;
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\CCM\\Security|Certificate Selection Criteria"),
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\SMS\\Client\\Internet Facing|Internet MP Hostname"),
InternetMPHostName;
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\CCM\\Security|Select First Certificate"),
[PropertyContext("local|HKEY_LOCAL_MACHINE\\Software\\Microsoft\\CCM\\Security|ClientAlwaysOnInternet"),
// Declare the class to prevent older clients from sending error status messages
#pragma namespace("\\\\.\\root")
instance of __Namespace
Name = "ccm" ;
#pragma namespace("\\\\.\\root\\ccm")
Name = "SoftwareMeteringAgent" ;
#pragma namespace("\\\\.\\root\\ccm\\SoftwareMeteringAgent")
class CCM_RecentlyUsedApps
[Key]
string FolderPath;
[Key]
string ExplorerFileName;
[Key]
string LastUserName;
string OriginalFileName;
string FileVersion;
uint32 FileSize;
string ProductName;
string ProductVersion;
string CompanyName;
uint32 ProductLanguage;
string FileDescription;
uint32 LaunchCount;
datetime LastUsedTime;
string ProductCode;
string AdditionalProductCodes;
string msiDisplayName;
string msiPublisher;
string msiVersion;
string SoftwarePropertiesHash;
string FilePropertiesHash;
Name = "ccm" ;
// CCM_LogicalMemoryConfiguration
#pragma namespace("\\\\.\\root\\cimv2")
[union,ViewSources{"select Name,FreeVirtualMemory,SizeStoredInPagingFiles,TotalVisibleMemorySize,TotalVirtualMemorySize from Win32_OperatingSystem"},ViewSpaces{"\\\\.\\root\\cimv2"},
dynamic,Provider("MS_VIEW_INSTANCE_PROVIDER")]
class CCM_LogicalMemoryConfiguration
[PropertySources{"FreeVirtualMemory"}]
uint64 AvailableVirtualMemory;
[PropertySources{"Name"},key]
string Name;
[PropertySources{"SizeStoredInPagingFiles"}]
uint64 TotalPageFileSpace;
[PropertySources{"TotalVisibleMemorySize"}]
uint64 TotalPhysicalMemory;
[PropertySources{"TotalVirtualMemorySize"}]
uint64 TotalVirtualMemory;
#pragma deleteclass("Win32_BitLockerEncryptionDetails", NOFAIL)
[union, ViewSources{"select DeviceId, BitlockerPersistentVolumeId, BitLockerManagementPersistentVolumeId, BitLockerManagementVolumeType, DriveLetter, Compliant, ReasonsForNonCompliance, KeyProtectorTypes, EncryptionMethod, ConversionStatus, ProtectionStatus, IsAutoUnlockEnabled, NoncomplianceDetectedDate, EnforcePolicyDate from Mbam_Volume"}, ViewSpaces{"\\\\.\\root\\microsoft\\mbam"}, dynamic, Provider("MS_VIEW_INSTANCE_PROVIDER")]
class Win32_BitLockerEncryptionDetails
[PropertySources{"DeviceId"},key]
String DeviceId;
[PropertySources{"BitlockerPersistentVolumeId"}]
String BitlockerPersistentVolumeId;
[PropertySources{"BitLockerManagementPersistentVolumeId"}]
String MbamPersistentVolumeId;
//UNKNOWN = 0, OS_Volume = 1, FIXED_VOLUME = 2, REMOVABLE_VOLUME = 3
[PropertySources{"BitLockerManagementVolumeType"}]
SInt32 MbamVolumeType;
[PropertySources{"DriveLetter"}]
String DriveLetter;
//VOLUME_NOT_COMPLIANT = 0, VOLUME_COMPLIANT = 1, NOT_APPLICABLE = 2
[PropertySources{"Compliant"}]
SInt32 Compliant;
[PropertySources{"ReasonsForNonCompliance"}]
SInt32 ReasonsForNonCompliance[];
[PropertySources{"KeyProtectorTypes"}]
SInt32 KeyProtectorTypes[];
[PropertySources{"EncryptionMethod"}]
SInt32 EncryptionMethod;
[PropertySources{"ConversionStatus"}]
SInt32 ConversionStatus;
[PropertySources{"ProtectionStatus"}]
SInt32 ProtectionStatus;
[PropertySources{"IsAutoUnlockEnabled"}]
Boolean IsAutoUnlockEnabled;
[PropertySources{"NoncomplianceDetectedDate"}]
String NoncomplianceDetectedDate;
[PropertySources{"EnforcePolicyDate"}]
String EnforcePolicyDate;
// Microsoft BitLocker Administration and Monitoring
String DeviceId;
String DriveLetter;
SInt32 Compliant;
#pragma namespace ("\\\\.\\root\\cimv2\\")
[DYNPROPS]
[key]
string KeyName;
//MBAM Agent fields
// Encoded Computer Name
[DYNPROPS]
Instance of Win32Reg_MBAMPolicy
KeyName="BitLocker policy";
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Policies\\Microsoft\\FVE\\MDOPBitLockerManagement|ShouldEncryptOsDrive"),Dynamic,Provider("RegPropProv")]
OsDriveEncryption;
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Policies\\Microsoft\\FVE\\MDOPBitLockerManagement|ShouldEncryptFixedDataDrive"),Dynamic,Provider("RegPropProv")]
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Policies\\Microsoft\\FVE|EncryptionMethod"),Dynamic,Provider("RegPropProv")]
EncryptionMethod;
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MBAM|OSVolumeProtectorPolicy"),Dynamic,Provider("RegPropProv")]
OsDriveProtector;
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Policies\\Microsoft\\FVE\\MDOPBitLockerManagement|AutoUnlockFixedDataDrive"),Dynamic,Provider("RegPropProv")]
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Policies\\Microsoft\\FVE|FDVPassphrase"),Dynamic,Provider("RegPropProv")]
//MBAM agent fields
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MBAM|MBAMPolicyEnforced"),Dynamic,Provider("RegPropProv")]
MBAMPolicyEnforced;
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MBAM|LastConsoleUser"),Dynamic,Provider("RegPropProv")]
LastConsoleUser;
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MBAM|UserExemptionDate"),Dynamic,Provider("RegPropProv")]
UserExemptionDate; //Registry value should be string in the format of yyyymmddHHMMSS.mmmmmmsUUU
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MBAM|MBAMMachineError"),Dynamic,Provider("RegPropProv")]
MBAMMachineError;
[PropertyContext("Local|HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MBAM|EncodedComputerName"),Dynamic,Provider("RegPropProv")]
#pragma deleteclass("CCM_OperatingSystemExtended", NOFAIL)
[union, ViewSources{"select Name,OperatingSystemSKU from Win32_OperatingSystem"}, ViewSpaces{"\\\\.\\root\\cimv2"},
class CCM_OperatingSystemExtended
string Name;
[PropertySources{"OperatingSystemSKU"}]
uint32 SKU;
#pragma deleteclass("CCM_ComputerSystemExtended", NOFAIL)
[union, ViewSources{"select Name,PCSystemType from Win32_ComputerSystem"}, ViewSpaces{"\\\\.\\root\\cimv2"},
class CCM_ComputerSystemExtended
string Name;
[PropertySources{"PCSystemType"}]
uint16 PCSystemType;
// Microsoft BitLocker Administration and Monitoring end
// Added extensions start
// Added extensions end
and this is sms_def.mof
[ SMS_Report (TRUE),
SMS_Group_Name ("BitLocker Encryption Details"),
SMS_Class_ID ("MICROSOFT|BITLOCKER_DETAILS|1.0")]
class Win32_BitLockerEncryptionDetails : SMS_Class_Template
[ SMS_Report (TRUE), key ]
String DeviceId;
String DriveLetter;
SInt32 Compliant;
[ SMS_Report(TRUE),
string KeyName;
[sMS_Report(TRUE)]
//MBAM Agent fields
[sMS_Report(TRUE)]
[sMS_Report(TRUE)]
[sMS_Report(TRUE)]
//Read Win32_OperatingSystem.SKU WMI property in a new class - because SKU is not available before Vista.
SMS_Group_Name ("Operating System Ex"),
SMS_Class_ID ("MICROSOFT|OPERATING_SYSTEM_EXT|1.0") ]
class CCM_OperatingSystemExtended : SMS_Class_Template
[sMS_Report (TRUE), key ]
string Name;
[sMS_Report (TRUE) ]
uint32 SKU;
//Read Win32_ComputerSystem.PCSystemType WMI property in a new class - because PCSystemType is not available before Vista.
SMS_Group_Name ("Computer System Ex"),
SMS_Class_ID ("MICROSOFT|COMPUTER_SYSTEM_EXT|1.0") ]
class CCM_ComputerSystemExtended : SMS_Class_Template
string Name;
When I try to import it I get this :
The MOF file you tried to import could not be compiled. Ensure that the MOF file contains valid data. You can use the command line mofcomp utility to test the data.
and
Expand
how to you append to the file? I have created another copy of the file and added the new part to the end of the file and saved it. When I try to overwrite the existing configuration.mof, it does not allow me to do so.
