Jamie3188 Posted July 14, 2015 Report post Posted July 14, 2015 Hi Everyone, When I try to PXE boot to my surface pro I get a really quick flash of an error (Which I had to capture with my slo-mo feature on my iPhone!!!) Message: Server IP Address is 192.168.23.246 (Which is correct) NBP filename is boot\x64xwdsmgfw.efi NBP filesize is 0 Bytes Then returns and boots up into windows. Any ideas what the problem is? Regards Jamie Quote Share this post Link to post Share on other sites More sharing options...
0 jifflemon Posted August 4, 2015 Report post Posted August 4, 2015 What OS are you running your WDS server on? Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted August 4, 2015 Report post Posted August 4, 2015 make sure you've populated the x64 bit boot image with the surface pro ethernet drivers on your PXE enabled DP, i describe the entire process in these videos, look at module 2 for starters http://www.windows-noob.com/forums/index.php?/topic/11685-5-video-series-on-deploying-the-microsoft-surface-pro-3-available-now/ Quote Share this post Link to post Share on other sites More sharing options...
Hi Everyone,
Message:
Regards
Jamie
