ykgreene
Surface Pro 3 wim Imaging
Good Afternoon,
I need to know how to deploy a customized wim of Windows 8.1 OS to the surface pro 3. The other thing is I want to retain the recovery partition of the surface pro 3, in case something goes wrong and I need to recover the device back to factory. Can anyone tell me how to do this? If you know of any documents that I can read up on this that would hel bottom line is i need help.
Also just fyi i will deploy wim via usb and pxe using a script to apply the wim to the OS index via WinPE 5.0.
