fbnella
Site Recovery Issue
I've shut down my old server and I'm trying to recover the site on new hardware with a site backup. It makes it all the way through until it gets to the SQL portion and it fails. SQL is installed on a separate machine and always has been. It connects fine but fails with the following error. Any help would be greatly appreciated.
INFO: Updated the site GUID in the registry. $$<Configuration Manager Setup><07-22-2015 12:38:20.752+300><thread=4796 (0x12BC)>
INFO: Resetting the installed hotfixes status on local SQL server sql01.harpethhall.org. $$<Configuration Manager Setup><07-22-2015 12:38:20.768+300><thread=4796 (0x12BC)>
INFO: Reset the installed hotfixes status on sql01.harpethhall.org. $$<Configuration Manager Setup><07-22-2015 12:38:20.799+300><thread=4796 (0x12BC)>
INFO: Registered type SMS_ACCESS for sql01.harpethhall.org CM_HH0 $$<Configuration Manager Setup><07-22-2015 12:38:20.799+300><thread=4796 (0x12BC)>
INFO: SQL Connection succeeded. Connection: SMS_ACCESS, Type: Secure $$<Configuration Manager Setup><07-22-2015 12:38:20.815+300><thread=4796 (0x12BC)>
INFO: SQL Connection succeeded. Connection: SMS ACCESS, Type: Secure $$<Configuration Manager Setup><07-22-2015 12:38:21.018+300><thread=4796 (0x12BC)>
*** if not exists (select * from AccountActionType where ActionID = 1) insert into AccountActionType(ActionID, Action) values (1, 'SyncProfiles') $$<Configuration Manager Setup><07-22-2015 12:38:21.034+300><thread=4796 (0x12BC)>
*** [42S02][208][Microsoft]
[sql Server]Invalid object name 'AccountActionType'.  $$<Configuration Manager Setup><07-22-2015 12:38:21.034+300><thread=4796 (0x12BC)>
ERROR: SQL Server error: [42S02][208][Microsoft][sql Server Native Client 11.0][sql Server]Invalid object name 'AccountActionType'. $$<Configuration Manager Setup><07-22-2015 12:38:21.049+300><thread=4796 (0x12BC)>
INFO: Executing SQL Server command: <if not exists (select * from AccountActionType where ActionID = 1) insert into AccountActionType(ActionID, Action) values (1, 'SyncProfiles')> $$<Configuration Manager Setup><07-22-2015 12:38:21.065+300><thread=4796 (0x12BC)>
ERROR: Failed to execute query: if not exists (select * from AccountActionType where ActionID = 1) insert into AccountActionType(ActionID, Action) values (1, 'SyncProfiles') $$<Configuration Manager Setup><07-22-2015 12:38:21.065+300><thread=4796 (0x12BC)>
