We just finished upgrading our SCCM Servers both our CAS and PS1 to SCCM 2012 R2 SP1.
After the upgrade it seems that the new boot.wim file that is created is having issues. After the machine pxe boots and pulls down the wim file, it goes to windows is starting up then preparing network connections and then black screens and restarts.
I opened up an F8 command prompt and pulled the SMSTS.log and I see an error during the TSMBootStrap.exe step.
The error is Failed to download pxe variable file ...
PxeGetPxeData failed with ....
I have attached our SMSTS.LOG file.
I verified that i have network connectivity by running IP config and then I was also able to ping our MP.
I thought it might be driver related but I have tested from different dell models, Dell 9020, E3340, 7010, etc. and they all have the same problem.
Any ideas/suggestions?
smsts.logFetching info...
