Gary Jack
Task Sequence process after PXE build is hit and miss whether it starts
We receive a DHCP address, Press F12 to PXE build, It loads the boot image, It starts the process and displays the message "Preparing Network Connections" then sometimes it loads the window with the available Task Sequences, however more often than not it doesn't display the screen and just reboots the machine. If you try the same process a number of times on the same machine it will eventually work as expected. This issue has only recently started this week and We have no idea what may be the cause of it. Any ideas would be greatly appreciated as we have over 300 pc to build in 3 weeks.
