jamios28
[Help] Failed to read installation type from environment Error: 80004005
I'm trying to boot a new computer HP ElitePad x2 and its failing on the step here : Failed to read installation type from environment Error: 80004005
Some information ;
- My TS works on other computers fine and I'm installing windows 8.1
- On Version SCCm 2007.
- My computer doesnt have a valid nic adpater, so we are using a Lenovo USB adapter.
- Booting via USB key.
Log is attached and I put main parts below.
Any help would be appriciated!
<![LOG[Failed to read installation type from environment.. Please ensure you are running this executable inside a properly configured OS Deployment task sequence.
Unspecified error (Error: 80004005; Source: Windows)]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="OSDWinSettings" context="" type="3" thread="1184" file="infanswerfile.cpp:325">
<![LOG[OSD::Utility::BaseAnswerFile::CreateAnswerFile( pAnswerFile ), HRESULT=80004005 (e:\nts_sms_fre\sms\client\osdeployment\osdwinsettings\osdwinsettings.cpp,364)]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="OSDWinSettings" context="" type="0" thread="1184" file="osdwinsettings.cpp:364">
<![LOG[Failed to initialize answer file.]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="OSDWinSettings" context="" type="3" thread="1184" file="osdwinsettings.cpp:364">
<![LOG[ConfigureWinSettings(), HRESULT=80004005 (e:\nts_sms_fre\sms\client\osdeployment\osdwinsettings\osdwinsettings.cpp,637)]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="OSDWinSettings" context="" type="0" thread="1184" file="osdwinsettings.cpp:637">
<![LOG[Failed to open the Task Sequencing Environment. Code 0x80004005. Please ensure you are running this executable inside a properly configured OS Deployment task sequence.
Unspecified error (Error: 80004005; Source: Windows)]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="OSDWinSettings" context="" type="3" thread="1184" file="osdwinsettings.cpp:637">
<![LOG[Exiting with return code 0x80004005]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="OSDWinSettings" context="" type="1" thread="1184" file="osdwinsettings.cpp:647">
<![LOG[Process completed with exit code 2147500037]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="commandline.cpp:1102">
<![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="instruction.cxx:3010">
<![LOG[Failed to run the action: Apply Windows Settings.
Unspecified error (Error: 80004005; Source: Windows)]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="3" thread="1100" file="instruction.cxx:3101">
<![LOG[sending status message . . .]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:292">
<![LOG[send a task execution status message SMS_TSExecution_ActionFailError]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:314">
<![LOG[MP server CA1SW17.CA1.GRS.NET and port 80. SSL=false. CRL=false.]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:458">
<![LOG[site code: CA1]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:489">
<![LOG[Client machine name: ca10Elitepadx5]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:494">
<![LOG[Client Identity: GUID:CC094F51-31C2-46E6-AAA3-AFD0A57EC498]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:496">
<![LOG[Advertisement ID: CA12002A]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:505">
<![LOG[Package ID: CA100055]LOG]!><time="08:32:15.914+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:507">
<![LOG[sending StatusMessage]LOG]!><time="08:32:15.929+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="libsmsmessaging.cpp:3806">
<![LOG[Formatted header:]LOG]!><time="08:32:15.929+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="libsmsmessaging.cpp:1500">
<![LOG[<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>32601EB7-061B-4B46-9305-FA753C355512</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2015-08-21T12:32:15Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="4248"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
]LOG]!><time="08:32:15.929+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="libsmsmessaging.cpp:1501">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: CA1SW17.CA1.GRS.NET:80 CCM_POST /ccm_system/request]LOG]!><time="08:32:15.929+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="libsmsmessaging.cpp:7446">
<![LOG[The request has succeeded. 200 OK]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="0" thread="1100" file="libsmsmessaging.cpp:7734">
<![LOG[set a global environment variable _SMSTSLastActionRetCode=-2147467259]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="0" thread="1100" file="executionenv.cxx:668">
<![LOG[set a global environment variable _SMSTSLastActionSucceeded=false]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="0" thread="1100" file="executionenv.cxx:668">
<![LOG[Clear local default environment]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="0" thread="1100" file="executionenv.cxx:807">
<![LOG[Let the parent group (Install Operating System) decides whether to continue execution]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="0" thread="1100" file="instruction.cxx:3210">
<![LOG[Let the parent group (Layer 1) decide whether to continue execution]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="0" thread="1100" file="instruction.cxx:2461">
<![LOG[The execution of the group (Layer 1) has failed and the execution has been aborted. An action failed.
Operation aborted (Error: 80004004; Source: Windows)]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="3" thread="1100" file="instruction.cxx:2424">
<![LOG[Failed to run the last action: Apply Windows Settings. Execution of task sequence failed.
Unspecified error (Error: 80004005; Source: Windows)]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="3" thread="1100" file="engine.cxx:214">
<![LOG[sending status message . . .]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:292">
<![LOG[send a task execution status message SMS_TSExecution_TaskSequenceFailError]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:314">
<![LOG[MP server CA1SW17.CA1.GRS.NET and port 80. SSL=false. CRL=false.]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:458">
<![LOG[site code: CA1]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:489">
<![LOG[Client machine name: ca10Elitepadx5]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:494">
<![LOG[Client Identity: GUID:CC094F51-31C2-46E6-AAA3-AFD0A57EC498]LOG]!><time="08:32:15.960+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:496">
<![LOG[Advertisement ID: CA12002A]LOG]!><time="08:32:15.976+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:505">
<![LOG[Package ID: CA100055]LOG]!><time="08:32:15.976+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="utility.cxx:507">
<![LOG[sending StatusMessage]LOG]!><time="08:32:15.976+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="libsmsmessaging.cpp:3806">
<![LOG[Formatted header:]LOG]!><time="08:32:15.976+240" date="08-21-2015" component="TSManager" context="" type="1" thread="1100" file="libsmsmessaging.cpp:1500">
