fsmith@neverware.com
Deploying Linux Using OSD - Error 80070057 - Help?
Hi All,
I'm using the following group of products:
Windows 2012 (not R2)
SCCM 2012 R2
Win PE 4.0
My goal is to deploy a Linux distribution by created an OSD task sequence, following these model:
http://blogs.msdn.com/b/steverac/archive/2014/01/02/osd-for-linux-imaging-yes-really.aspx
http://systemcenter.no/?p=509
I recognize that this is not supported by design, but dd is a simple enough tool that I am hoping I can make this work easily.
So the Order of operations is:
1) Attach to remote location with dd executable and image we're trying to deploy
2) Clean disk on client
3) run command : "dd if=image.bin of=\\?\harddisk0\partition0 bs=4M --progress"
However I'm running into the error 80070057, among others you'll see in the logs.
Some details: for reasons outside the scope of this task, I am aiming to deploy to the entire disk. Reserving a partition will, I think, break the update system on my linux distro.
Willing to try anything - would love to get some help!
Here's the log (also attached):
https://gist.github.com/smithforrestr/a83d6b154bc459eea62e#file-smsts-log
smsts.txtFetching info...
4 answers to this question
the 80070057 error means
  Quote
The parameter is incorrect.
Source: Windows
so are you using a command incorrectly, i havn't tried what you are trying to do so i cannot offer advice sorry
at what point is yours failing, 1,2,3 ?
Thanks for the reply!
I *believe* I'm failing at step 3. However, the dd command I'm running definitely works - I've confirmed as much by running it manually while live-booted into WinPE and the installation works.
Based on the logs near the end, it would appear that there is something else causing step 3 to fail - I think it is that none of my files are present somehow. If you look at the log-section below, you can see that after disk cleanup finished successfully there is another error (perhaps more telling) : "nPos != String::npos, HRESULT=800700a1"
  Quote
<![LOG[successfully completed the action (Disk Clean up) with the exit win32 code 0]LOG]!><time="09:33:26.860+240" date="08-24-2015" component="TSManager" context="" type="1" thread="292" file="instruction.cxx:830">
<![LOG[MP server http://SCCM-R720-W12.methacton.org. Ports 80,443. CRL=false.]LOG]!><time="09:33:26.860+240" date="08-24-2015" component="TSManager" context="" type="1" thread="292" file="utils.cpp:5881">
<![LOG[setting authenticator]LOG]!><time="09:33:26.907+240" date="08-24-2015" component="TSManager" context="" type="1" thread="292" file="utils.cpp:5903">
<![LOG[set authenticator in transport]LOG]!><time="09:33:26.907+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="libsmsmessaging.cpp:7734">
<![LOG[sending StatusMessage]LOG]!><time="09:33:27.110+240" date="08-24-2015" component="TSManager" context="" type="1" thread="292" file="libsmsmessaging.cpp:4023">
<![LOG[setting message signatures.]LOG]!><time="09:33:27.130+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="libsmsmessaging.cpp:1295">
<![LOG[setting the authenticator.]LOG]!><time="09:33:27.130+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="libsmsmessaging.cpp:1325">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SCCM-R720-W12.methacton.org:80 CCM_POST /ccm_system/request]LOG]!><time="09:33:27.130+240" date="08-24-2015" component="TSManager" context="" type="1" thread="292" file="libsmsmessaging.cpp:8604">
<![LOG[Request was successful.]LOG]!><time="09:33:27.161+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="libsmsmessaging.cpp:8939">
<![LOG[set a global environment variable _SMSTSLastActionRetCode=0]LOG]!><time="09:33:27.161+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:668">
<![LOG[set a global environment variable _SMSTSLastActionSucceeded=true]LOG]!><time="09:33:27.161+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:668">
<![LOG[Expand a string: %_SMSTSMDataPath%\Logs]LOG]!><time="09:33:27.161+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:782">
<![LOG[nPos != String::npos, HRESULT=800700a1 (e:\nts_sccm_release\sms\framework\core\ccmcore\path.cpp,101)]LOG]!><time="09:33:27.176+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="path.cpp:101">
<![LOG[RecursiveCreatePath(sPath.substr(0, nPos), psa), HRESULT=800700a1 (e:\nts_sccm_release\sms\framework\core\ccmcore\path.cpp,104)]LOG]!><time="09:33:27.176+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="path.cpp:104">
<![LOG[RecursiveCreatePath( sNormalizedPath, psa ), HRESULT=800700a1 (e:\nts_sccm_release\sms\framework\core\ccmcore\path.cpp,159)]LOG]!><time="09:33:27.176+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="path.cpp:159">
<![LOG[Path::Create( destDirectory, Security::SecurityAttributes(LogSecurity) ), HRESULT=800700a1 (e:\qfe\nts\sms\framework\tscore\tslogging.cpp,987)]LOG]!><time="09:33:27.176+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="tslogging.cpp:987">
<![LOG[Clear local default environment]LOG]!><time="09:33:27.176+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:807">
<![LOG[user did not specify local data drive]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="utils.cpp:1974">
<![LOG[Volume X:\ is not a fixed hard drive]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="1" thread="292" file="utils.cpp:1077">
<![LOG[TSM root drive = ]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="1" thread="292" file="utils.cpp:1142">
<![LOG[We do not find an available volume to store the local data path]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="1" thread="292" file="utils.cpp:1989">
<![LOG[set a global environment variable _SMSTSNextInstructionPointer=2]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:668">
<![LOG[set a TS execution environment variable _SMSTSNextInstructionPointer=2]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:386">
<![LOG[set a global environment variable _SMSTSInstructionStackString=]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:668">
<![LOG[set a TS execution environment variable _SMSTSInstructionStackString=]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:414">
<![LOG[save the current environment block]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:833">
<![LOG[pszPath[0] != L'\0', HRESULT=80070057 (e:\nts_sccm_release\sms\framework\core\ccmcore\path.cpp,60)]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="path.cpp:60">
<![LOG[Filesystem::Path::Add(sEnvPath, EnvDataFileName, sEnvPath), HRESULT=80070057 (e:\qfe\nts\sms\framework\tscore\environmentlib.cpp,676)]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="environmentlib.cpp:676">
<![LOG[Failed to save environment to (80070057)]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="2" thread="292" file="environmentlib.cpp:697">
<![LOG[TS::Environment::SharedEnvironment.saveEnvironment(szPath), HRESULT=80070057 (e:\nts_sccm_release\sms\client\tasksequence\executionengine\executionenv.cxx,842)]LOG]!><time="09:33:27.333+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:842">
<![LOG[Failed to save the current environment block. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
The parameter is incorrect. (Error: 80070057; Source: Windows)]LOG]!><time="09:33:27.348+240" date="08-24-2015" component="TSManager" context="" type="3" thread="292" file="executionenv.cxx:842">
<![LOG[saveEnvironment(), HRESULT=80070057 (e:\nts_sccm_release\sms\client\tasksequence\executionengine\executionenv.cxx,420)]LOG]!><time="09:33:27.348+240" date="08-24-2015" component="TSManager" context="" type="0" thread="292" file="executionenv.cxx:420">
The process around "User did not specify a local data drive" also diverges from the logs in the beginning. It first checks is drive X:\ is right, passes over it, and then fails (early in the logs it does this process, but proceeds to locate drive D:\ and use that.
SO I am suspicious that perhaps my disk-clean operation is destroying the dd.exe file and image that I downloaded to use in this imaging process?
I'm pretty new at using this tool, so any insight at all is helpful!
if it can't store the files on a suitable drive then it will fail, i don't know how you'll store your files somewhere other than x:, you can't store them in x: and the task sequence wants to store them on a drive formatted as NTFS
how you move forward with it i dont know,
