mmenzie Posted August 27, 2015 Report post Posted August 27, 2015 i am so confused... maybe someone can help me.... i am no SCCM expert by any means. just because i was curious i followed a guide to get your environment ready to capture and deploy windows 10. it said to uninstall and previous ADK's and install the windows 10 ADK. i followed the guide all the way through. now my company wants to try and deploy windows 7 with SCCM (we were using acronis which is why i was testing windows 10 with SCCM since it was not being used for windows 7) so now i look and my windows 7 boot images are gone so i am guessing i have to uninstall the windows 10 ADK and put the windows 7 ADK back??is that true?? is there a way to have support to deploy both windows 7 and windows 10 on the same SCCM server?? Quote Share this post Link to post Share on other sites More sharing options...
HotdogSCCM Posted August 27, 2015 Report post Posted August 27, 2015 You can use the Windows 10 ADK derived boot image to deploy Windows 7 WIMs. Create your new Windows 10 boot images, and use those instead on the Task Sequence. Quote Share this post Link to post Share on other sites More sharing options...
