regan
OSD windows 10 same Ethernet Adapter Script issue
first off thanks to creators if the script listen below
in a nut shell i want to use the same USB-Ethernet adapter for lots of deployments. The Wifi is connected at the point where it asks me to remove the USB adapter( i can ping my server when the adapter is disconnected ) but power shell isn't my strong point so i'm wondering if there is something in Windows 10 which is effecting the script.
Exception calling "TriggerSchedule" : "Not found " RunPowerShellScript 02/09/2015 11:07:14 2712 (0x0A98)
At C:\_SMSTaskSequence\Packages\NOX00112\AssociateWiFi.ps1:52 char:1 RunPowerShellScript 02/09/2015 11:07:14 2712 (0x0A98)
+ $SMSCli.triggerschedule("{00000000-0000-0000-0000-000000000003}") RunPowerShellScript 02/09/2015 11:07:14 2712 (0x0A98)
+ CategoryInfo : NotSpecified: ( :) [], MethodInvocationException RunPowerShellScript 02/09/2015 11:07:14 2712 (0x0A98)
+ FullyQualifiedErrorId : WMIMethodException RunPowerShellScript 02/09/2015 11:07:14 2712 (0x0A98)
Successfully finalized logs to SMS client log directory from C:\WINDOWS\CCM\Logs OSDSetupHook 02/09/2015 11:09:34 2776 (0x0AD8)
to me it looks like its not finding Discovery Inventory but i could be miles off
https://gallery.technet.microsoft.com/scriptcenter/Enable-multiple-SCCM-OS-861e42bb
smsts.log
Does the script run in WinPE? There are known issues with the Windows 10 ADK that Powershell script fails in WinPE when PXE booted. could be the reason.
Why not use this method to filter out the USB NIC making it re-usable for all machines. http://blogs.technet.com/b/configurationmgr/archive/2015/08/27/reusing-the-same-nic-for-multiple-pxe-initiated-deployments-in-system-center-configuration-manger-osd.aspx
Regards,
Jörgen
Regards,
Jörgen
Yes it does run in WINPE, so could well be this issue. I will have a look at the post and might have to give that a try, shame its not more automated as ive got lots of devices either way Thanks for the link
