geckostech
Management Point failing since 2012R2 SP1 Upgrade
I've been having a problem with one of my management points since I upgraded to Configuration Manager 2012R2 SP1 CU1 on Server 2012R2. The management point doesn't seem to be communicating with clients. in mpcontrol log I get this repeating:
SSL is enabled. SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
Client authentication is also enabled. SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
CRL Checking is also enabled. SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
Machine name is 'blahblahblah.local'. SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
Begin validation of Certificate [Thumbprint ebf1c024fbffc3bbf6e46bb098bf291b6020a540] issued to 'blahblahblah.local' SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
Certificate has "SSL Client Authentication" capability. SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
Completed validation of Certificate [Thumbprint ebf1c024fbffc3bbf6e46bb098bf291b6020a540] issued to 'blahblahblah.local' SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
>>> Selected Certificate [Thumbprint ebf1c024fbffc3bbf6e46bb098bf291b6020a540] issued to 'blahblahblah.local' for HTTPS Client Authentication SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
Call to HttpSendRequestSync failed for port 443 with status code 500, text: Internal Server Error SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
Sent summary record of SMS Management Point on ["Display=\\blahblahblah.LOCAL\"]MSWNET:["SMS_SITE=site"]\\blahblahblah.LOCAL\ to E:\SMS\MP\OUTBOXES\sitestat.box\0wco2fhb.SUM, Availability 1, 366998524 KB total disk space , 365956168 KB free disk space, installation state 0. SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:29 3944 (0x0F68)
Successfully performed Management Point availability check against local computer. SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:30 3944 (0x0F68)
Initialization still in progress. SMS_MP_CONTROL_MANAGER 07/09/2015 09:49:30 3944 (0x0F68)
I read somewhere about WMI causing the client to repair repeatedly and sure enough in ccmrepair.log I am getting this repeating:
Initiating repair. CcmRepair 07/09/2015 10:30:24 6524 (0x197C)
Ccmsetup returned exit code 0 CcmRepair 07/09/2015 10:47:58 408 (0x0198)
Success CcmRepair 07/09/2015 10:47:58 408 (0x0198)
Repair complete. CcmRepair 07/09/2015 10:47:58 408 (0x0198)
Running query 'SELECT * FROM CCM_Service_HostedApplication WHERE Type="Server"' against namespace: '\\.\ROOT\CCM\Policy\Machine' CcmRepair 07/09/2015 10:48:09 1600 (0x0640)
CCMExec is currently NOT hosting a server application. CcmRepair 07/09/2015 10:48:09 1600 (0x0640)
Checking product registrations. CcmRepair 07/09/2015 10:48:09 1600 (0x0640)
Found product code = {948643F6-8526-4555-93DA-6EBF50CA7650} CcmRepair 07/09/2015 10:48:09 1600 (0x0640)
Found product "ConfigMgr Distribution Point" version 5.00.7804.1000 upgrade code {31CEACF7-394A-4FF4-B591-2E7B0E0F90B8} CcmRepair 07/09/2015 10:48:10 1600 (0x0640)
Found product code = {343D4507-997F-4553-9F86-2BB81F19A05E} CcmRepair 07/09/2015 10:48:10 1600 (0x0640)
Found product "Configuration Manager Client" version 5.00.8239.1000 upgrade code {252DA259-82CA-4177-B8D0-49C78937BA3E} CcmRepair 07/09/2015 10:48:10 1600 (0x0640)
Looking for product code '{343D4507-997F-4553-9F86-2BB81F19A05E}' in WMI CcmRepair 07/09/2015 10:48:10 1600 (0x0640)
Confirmed registration for product "Configuration Manager Client". CcmRepair 07/09/2015 10:48:10 1600 (0x0640)
Looking for product code '{948643F6-8526-4555-93DA-6EBF50CA7650}' in WMI CcmRepair 07/09/2015 10:48:10 1600 (0x0640)
Could not get registration for product "ConfigMgr Distribution Point". Repair required. WMI returned (80041002) CcmRepair 07/09/2015 10:48:10 1600 (0x0640)
I have tried completely stripping the server down and removing all IIS, wsus, DP roles, the files for those roles, manually removing the client and all associated services and registry keys, and if I think reinstall the client, it is fine. As soon as I turn the server back into a site system server again however, the same issue starts.
Help, I am stuck.
I beleive this has to do with the SCCM client being installed on the MP as well. How did you uninstall it? You need to uninstall it and remove the informaiton in WMI,
The command in this blog post should work for in this scenario as well.
http://scug.be/sccm/2013/05/14/cm12-sp1-management-point-will-not-install-on-server-2012/
Regards,
Jörgen
I thought it has worked, the client is off, but now I am getting this in ccmrepair.log:
Running query 'SELECT * FROM CCM_Service_HostedApplication WHERE Type="Server"' against namespace: '\\.\ROOT\ccm\Policy\Machine' CcmRepair 07/09/2015 14:51:42 2128 (0x0850)
CCMExec is supporting application versions 5.0.7000.* through 5.0.9000.* CcmRepair 07/09/2015 14:51:42 2128 (0x0850)
CCMExec is currently hosting a server application. CcmRepair 07/09/2015 14:51:42 2128 (0x0850)
Checking product registrations. CcmRepair 07/09/2015 14:51:42 2128 (0x0850)
Found product code = {948643F6-8526-4555-93DA-6EBF50CA7650} CcmRepair 07/09/2015 14:51:42 2128 (0x0850)
Found product "ConfigMgr Distribution Point" version 5.00.7804.1000 upgrade code {31CEACF7-394A-4FF4-B591-2E7B0E0F90B8} CcmRepair 07/09/2015 14:54:14 2128 (0x0850)
Found product code = {861C35CB-8117-469B-A847-D948AEE1F507} CcmRepair 07/09/2015 14:54:14 2128 (0x0850)
Found product "ConfigMgr Management Point" version 5.00.8239.1000 upgrade code {ABD0F60F-1622-4311-8989-106B60D784FF} CcmRepair 07/09/2015 14:54:14 2128 (0x0850)
Looking for product code '{948643F6-8526-4555-93DA-6EBF50CA7650}' in WMI CcmRepair 07/09/2015 14:54:14 2128 (0x0850)
Could not get registration for product "ConfigMgr Distribution Point". Repair required. WMI returned (80041002) CcmRepair 07/09/2015 14:54:14 2128 (0x0850)
Initiating repair. CcmRepair 07/09/2015 14:59:14 104 (0x0068)
Repairing CCM products CcmRepair 07/09/2015 14:59:14 4044 (0x0FCC)
Repairing product {948643F6-8526-4555-93DA-6EBF50CA7650} CcmRepair 07/09/2015 14:59:14 4044 (0x0FCC)
Upgrade Code = {31CEACF7-394A-4FF4-B591-2E7B0E0F90B8} CcmRepair 07/09/2015 14:59:14 4044 (0x0FCC)
MSI will log to E:\SMS_CCM\logs\repair-msi-948643F6-8526-4555-93DA-6EBF50CA7650.log CcmRepair 07/09/2015 14:59:14 4044 (0x0FCC)
Couldn't get ccmsetup path. Repair the client msi directly. CcmRepair 07/09/2015 14:59:14 4044 (0x0FCC)
Installation failed. Check log file for details CcmRepair 07/09/2015 14:59:16 4044 (0x0FCC)
Repairing product {861C35CB-8117-469B-A847-D948AEE1F507} CcmRepair 07/09/2015 14:59:16 4044 (0x0FCC)
Upgrade Code = {ABD0F60F-1622-4311-8989-106B60D784FF} CcmRepair 07/09/2015 14:59:16 4044 (0x0FCC)
Installed product is Management Point CcmRepair 07/09/2015 14:59:16 4044 (0x0FCC)
MSI will log to E:\SMS_CCM\logs\repair-msi-861C35CB-8117-469B-A847-D948AEE1F507.log CcmRepair 07/09/2015 14:59:16 4044 (0x0FCC)
Repairing Management Point with command line: REINSTALL=ALL REINSTALLMODE=vmaus USESMSPORTS=TRUE SMSPORTS=80 USESMSSSLPORTS=TRUE SMSSSLPORTS=443 USESMSSSL=TRUE SMSSSLSTATE=63 CCMENABLELOGGING=TRUE CCMLOGLEVEL=1 CCMLOGMAXSIZE=1000000 CCMLOGMAXHISTORY=1 CcmRepair 07/09/2015 14:59:16 4044 (0x0FCC)
Running query 'SELECT * FROM CCM_Service_HostedApplication WHERE Type="Server"' against namespace: '\\.\ROOT\ccm\Policy\Machine' CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
CCMExec is supporting application versions 5.0.7000.* through 5.0.9000.* CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
CCMExec is currently hosting a server application. CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
Checking product registrations. CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
Found product code = {948643F6-8526-4555-93DA-6EBF50CA7650} CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
Found product "ConfigMgr Distribution Point" version 5.00.7804.1000 upgrade code {31CEACF7-394A-4FF4-B591-2E7B0E0F90B8} CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
Found product code = {861C35CB-8117-469B-A847-D948AEE1F507} CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
Found product "ConfigMgr Management Point" version 5.00.8239.1000 upgrade code {ABD0F60F-1622-4311-8989-106B60D784FF} CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
Looking for product code '{948643F6-8526-4555-93DA-6EBF50CA7650}' in WMI CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
Could not get registration for product "ConfigMgr Distribution Point". Repair required. WMI returned (80041002) CcmRepair 07/09/2015 15:00:45 4496 (0x1190)
Initiating repair. CcmRepair 07/09/2015 15:05:45 1352 (0x0548)
Success CcmRepair 07/09/2015 15:05:54 4044 (0x0FCC)
Repair complete. CcmRepair 07/09/2015 15:05:54 4044 (0x0FCC)
and this in mpcontrol.log:
SSL is enabled. SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
Client authentication is also enabled. SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
CRL Checking is also enabled. SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
Machine name is 'blahblahblah.local'. SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
Begin validation of Certificate [Thumbprint ebf1c024fbffc3bbf6e46bb098bf291b6020a540] issued to 'blahblahblah.local.local' SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
Certificate has "SSL Client Authentication" capability. SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
Completed validation of Certificate [Thumbprint ebf1c024fbffc3bbf6e46bb098bf291b6020a540] issued to 'blahblahblah.local.local' SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
>>> Selected Certificate [Thumbprint ebf1c024fbffc3bbf6e46bb098bf291b6020a540] issued to 'blahblahblah.local.local' for HTTPS Client Authentication SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
Call to HttpSendRequestSync failed for port 443 with status code 500, text: Internal Server Error SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
Sent summary record of SMS Management Point on ["Display=\\blahblahblah.local.LOCAL\"]MSWNET:["SMS_SITE=site"]\\blahblahblah.local.LOCAL\ to E:\SMS\MP\OUTBOXES\sitestat.box\xqhc2f3q.SUM, Availability 1, 366998524 KB total disk space , 338284764 KB free disk space, installation state 0. SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
Successfully performed Management Point availability check against local computer. SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
Initialization still in progress. SMS_MP_CONTROL_MANAGER 07/09/2015 15:09:28 4036 (0x0FC4)
