Sypher
Problems with SCCM 2007 SP2 + MDT 2010
I've been evaluating the use of SCCM - err ConfigMgr like Microsoft would like you to call it - and I've came across MDT 2010.
This seemed interesting so I've installed it. I was running R2 but since I've read it requires SP2 I've upgraded my installation.
This however did not change the situation.
I am trying to generate a MDT Boot image from the SCCM mmc. This process is working hard and then suddenly complains that "The ConfigMgr reported an error".
Geeh sparky, seriously? Really informative :)
smsprov.log states the following:
[FC4][Fri 10/09/2009 11:57:52]:Using SMS SERVICE Account for impersonation
[FC4][Fri 10/09/2009 11:57:52]:SMS ACCOUNT WORK SUCCEEDED
[FC4][Fri 10/09/2009 11:57:52]:GetStorage : doing Loggin due to aged out context
[FC4][Fri 10/09/2009 11:57:52]: -- Updating NT User Group membership.
[FC4][Fri 10/09/2009 11:57:52]:Image language ID 1043 and nl-NL
[FC4][Fri 10/09/2009 11:57:53]:Image language ID 1043 and nl-NL
[FC4][Fri 10/09/2009 11:57:53]:ERROR> failed to mount wim file err=-2147024894
Google nor this site's search is giving me any useful hits.
I was wondering, does anyone know how to fix this? I tried downgrading WAIK but this didn't seem to work either.
Looking forward to your replies!
Thanks in advance.
Sypher
so you have installed SP2 RC yes ?
and you have integrated MDT 2010 into SCCM by right-clicking on configure ConfigMgr Integration and choosing Run As Administrator ?
Thanks for your reply anyweb :)
Indeed, its the SP2 RC from MS Connect.. They have been integrated using the startmenu item.
Run as Administrator isn't really necessary since I'm logged in as Domain Administrator, right? :)
if you are running server 2008 then it's necessary, so what OS are you running ?
Win2k8 Enterprise x64.. But the integration is working, since I have the options available..
It fails when I try to generate a boot image for MDT2010.
And after pressing OK:
when you click on View Problem details, what does it say ?
Description:
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: mmc.exe
Problem Signature 02: 6.1.7600.16385
Problem Signature 03: 4a5bc808
Problem Signature 04: System.Windows.Forms
Problem Signature 05: 2.0.0.0
Problem Signature 06: 4a275ebd
Problem Signature 07: 1521
Problem Signature 08: 18
Problem Signature 09: System.InvalidOperationException
OS Version: 6.1.7600.2.0.0.274.10
Locale ID: 1043
Read our privacy statement online:
http://go.microsoft....88&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
This only happens when the ConfigMgr MMC is not being "Run As" Administrator..
Apart from the crash, there is no real difference. Either way, it still won't create a MDT-Bootimage..
when i mentioned Run As I was referring to the MDT integration,
ie: can you please install the MDT integration using RUN AS
once done, try recreating the boot image
I've already done that multiple times, both with and without RUN AS.
There is no difference, both times the image creation fails.
