I have a scenario, where we have a CAS and 2 primary sites (A & B under the CAS.
Will all the systems reporting as SCCM clients to primary site A,
also show in the console for primary site B (though their assignation will be to primary site A)
(based on the global data\site data logic under SQL replication)?
It is not practical. As you change the boundaries first but the site server is down. so...
Even if you can do it, it would take days to fully, migrate all clients to the other primary site. At this point you might as well re-build your broken site or create a whole new site.
