fsoares Posted October 16, 2015 Report post Posted October 16, 2015 I cant get data in the database unless i run the runmetersumm. I have looked at the logs and i dont see anything wrong. Should i be looking for something in special.. ? Also .. is there a place where i can see the date and time the data is supposed to be summarized ? Thank you. Quote Share this post Link to post Share on other sites More sharing options...
0 GarthMJ Posted October 17, 2015 Report post Posted October 17, 2015 Do you have the maintenance task enable? That is there you will see when they will run next. Quote Share this post Link to post Share on other sites More sharing options...
0 fsoares Posted October 19, 2015 Report post Posted October 19, 2015 Are you talking about the sumarization tasks in site maintenance ? Quote Share this post Link to post Share on other sites More sharing options...
0 GarthMJ Posted October 19, 2015 Report post Posted October 19, 2015 Yes, those are the ones. Quote Share this post Link to post Share on other sites More sharing options...
0 fsoares Posted October 19, 2015 Report post Posted October 19, 2015 They are enabled... i enabled the metering rules 10 days ago... at the 7th day i should had some data coming in... which was last Friday ... today its monday and i have nothing in... Quote Share this post Link to post Share on other sites More sharing options...
0 fsoares Posted October 19, 2015 Report post Posted October 19, 2015 and sumarization is occurring everyday at 4 am Quote Share this post Link to post Share on other sites More sharing options...
0 GarthMJ Posted October 19, 2015 Report post Posted October 19, 2015 On 10/19/2015 at 12:45 PM, fsoares said: They are enabled... i enabled the metering rules 10 days ago... at the 7th day i should had some data coming in... which was last Friday ... today its monday and i have nothing in... It depend on the report, it can take 37 days before some of the SW metering report will have data. Have you confirmed that the SWM rules are setup correctly and enabled? Quote Share this post Link to post Share on other sites More sharing options...
0 fsoares Posted October 19, 2015 Report post Posted October 19, 2015 the reports are the software metering ones, that come by default. The SWM rules are enabled for over 10 days. What do you mean by setup correctly ? this is what i have created. Quote Share this post Link to post Share on other sites More sharing options...
0 fsoares Posted October 19, 2015 Report post Posted October 19, 2015 Does the original file names have to be exact the same ? I created the rule manualy.. without importing it. Will it make a difference ? Quote Share this post Link to post Share on other sites More sharing options...
0 fsoares Posted October 19, 2015 Report post Posted October 19, 2015 I am using the WMI Explorer and the rules have been applied to the machines. Quote Share this post Link to post Share on other sites More sharing options...
0 GarthMJ Posted October 19, 2015 Report post Posted October 19, 2015 On 10/19/2015 at 12:58 PM, fsoares said: the reports are the software metering ones, that come by default. The SWM rules are enabled for over 10 days. What do you mean by setup correctly ? this is what i have created. Just because there is a rule doesn't mean it is enable, Are the Rule enabled? Notice that TimeHorton.exe is not enabled. Quote Share this post Link to post Share on other sites More sharing options...
Thank you.
