blind3d
SCCM error 80004005 - no BiOS issue - driving me crazy!
Hey guys,
I hope that you can help me out. Here is my situation:
-Using SCCM 2012 R1
-Usually deploying Windows 7 to Lenovo and Acer PCs - works perfect
-Got new industrial PCs by MSI now (Windbox II) - that had no UUID which I fixed with AMIDMI.exe /u etc.
-Task sequence starts like this:
2015_11_06_08_06_54_m_Remote_Witte_xml.p
-Step 2&3 check wether it's UEFI or not and partitions the disk
-Step 4 executes a script to allow me to give the machine a hostname
-This task sequence is used (in modified versions) for different PCs with different images and works for all of them
The issue:
As soon as I start the TS for the Windboxes, step 3 is chosen and completed succesfully (BIOS) but step 4 is ignored with the following error as logged in SMSTS.log:
2015_11_06_08_24_43_Configuration_Manage
What makes me wonder is the following message and I don't know if it is normal (CRL=false):
During Step3
2015_11_06_08_26_52_Configuration_Manage
Step 4
2015_11_06_08_25_46_Configuration_Manage
The most confusing thing about all that errors is, that 1 out of 15 attempts suddenly works and if you reboot the deployment fails again :-/ it doesn't even matter if I chose IDE or SATA in BiOS :(
I also tried a different HDD that works in our Lenovo devices btw. Log is attached as well (replaced the real name with fictional ;) ).
So when the TS starts to apply the OS it fails with 80004005 error.
Thanks in advance.
PS: Please move my post to this subforum: Configuration Manager 2012
Thnks.
Problem solved:
Hi again,
I think the issue is solved, but it doesn't really make sense to me, cuz it is incredibly stupid.. I tested the "workaround" 5 times now..
As we all know you're prompted to strike F12 for SCCM PE boot.
To avoid missing this step I hit F12 repeatedly which caused the TS to fail!!
If I only strike F12 when prompted the TS works properly..
If there is anyone out there who is able to explain this, just lemme know..
Maybe a secret AMI Bios command like in this case?
http://www.windows-noob.com/forums/topic/6240-toolkit-error-during-beginning-of-osd-ts/
smstsv2.logFetching info...
0 answers to this question
