willisj318
Two issues after R2 SP1 upgrade
We have upgraded SCCM from R2 to R2 w/ SP1 and CU1, we have not done CU2 yet, although I don't see fixes for these two issues listed in there.
Issue 1. Anyone that is not a full admin (maybe more accurately, anyone set up with custom security) cannot deploy a task sequence with a required purpose. If they set the purpose as available, they can deploy it fine. This was working fine prior to the upgrade. What happens is when they hit the NEXT button on the deployment settings screen, it pauses a moment like it is processing, then refreshes to the same screen.
Issue 2. Software inventory processing on the primary sites takes 30 seconds up to 1:30 to process a file single file, resulting in a backlog. Typically its around a minute per file. Again working fine prior to the upgrade. These are all delta as far as I can tell.
Any help is appreciated!
