ruffsense
ThinInstaller with sccm 2012 r2 sp1 problem
I have made a task to update drivers for a lenovo E550 Laptop.
First task: command line (Run ThinINstaller TrustZone)
cmd /c C:\Windows\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust
Disable 64-bit file systems redirection
Second task: command line (CMD Copy ThinInstaller)
cmd /c xcopy.exe "\\x.x.x.x\Sources\ThinInst\*.*" C:\Thinstaller\ /E /D
Time-outs: 15 minutes
Third Task: command line (CMD Run ThinInstaller)
cmd /c C:\Thinstaller\thininstaller.exe /CM -search A -action INSTALL -noicon -includerebootpackages 1,2,3,4 -repository "\\x.x.x.x\Sources\os_drivers\Laptops\E550" -log "C:\Thinstaller\tvsulog.txt"
Start in: C:\Thinstaller
Time-outs: 120 minutes
Error:
Failed to run the action: Run ThinINstaller TrustZone.
Incorrect function. (Error: 00000001; Source: Windows)
Expand a string: smsswd.exe /run: cmd /c %windir%\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
Expand a string: 	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
Command line for extension .exe is "%1" %*	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
Set command line: smsswd.exe /run: cmd /c %windir%\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
Start executing the command line: smsswd.exe /run: cmd /c %windir%\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\10.160.14.25\Sources\os_drivers\Laptops\E550\ FullTrust	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
!--------------------------------------------------------------------------------------------!	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
Expand a string: WinPEandFullOS	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
Executing command line: smsswd.exe /run: cmd /c %windir%\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
[ smsswd.exe ]	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
PackageID = ''	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
BaseVar = '', ContinueOnError=''	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
ProgramName = 'cmd /c X:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust'	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
SwdAction = '0001'	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
Set command line: Run command line	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
Working dir 'not set'	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
Executing command line: Run command line	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
Process completed with exit code 1	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
Command line returned 1	InstallSoftware	1/11/2016 7:16:25 PM	1168 (0x0490)
Process completed with exit code 1	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
Incorrect function. (Error: 00000001; Source: Windows)	TSManager	1/11/2016 7:16:25 PM	268 (0x010C)
Can anyone help me out?
Edited by ruffsense
can you manually run
cmd /c X:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\10.160.14.25\Sources\os_drivers\Laptops\E550\ FullTrust
is it intended to be running in WinPE or windows ?
I changed the task.
But still i get the error.
Expand a string: smsswd.exe /run: cmd /c C:\Windows\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
Expand a string: 	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
Command line for extension .exe is "%1" %*	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
Set command line: smsswd.exe /run: cmd /c C:\Windows\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
Start executing the command line: smsswd.exe /run: cmd /c C:\Windows\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
!--------------------------------------------------------------------------------------------!	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
Expand a string: WinPEandFullOS	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
Executing command line: smsswd.exe /run: cmd /c C:\Windows\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
[ smsswd.exe ]	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
PackageID = ''	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
BaseVar = '', ContinueOnError=''	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
ProgramName = 'cmd /c C:\Windows\Microsoft.NET\Framework\v4.0.30319\CasPol.exe –pp off –m –ag 1.2 –url file://\\x.x.x.x\Sources\os_drivers\Laptops\E550\ FullTrust'	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
SwdAction = '0001'	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
Set command line: Run command line	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
Working dir 'not set'	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
Executing command line: Run command line	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
Process completed with exit code 1	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
Command line returned 1	InstallSoftware	1/11/2016 7:59:58 PM	1576 (0x0628)
Process completed with exit code 1	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
Incorrect function. (Error: 00000001; Source: Windows)	TSManager	1/11/2016 7:59:58 PM	404 (0x0194)
I disabled the task and it fails on the second task.
Error:
Failed to run the action: CMD Copy ThinInstaller.
The system cannot open the file. (Error: 00000004; Source: Windows)
Expand a string: smsswd.exe /run: cmd /c xcopy.exe "\\x.x.x.x\Sources\ThinInst\*.*" C:\Thinstaller\ /E /D	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
Expand a string: 	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
Command line for extension .exe is "%1" %*	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
Set command line: smsswd.exe /run: cmd /c xcopy.exe "\\x.x.x.x\Sources\ThinInst\*.*" C:\Thinstaller\ /E /D	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
Start executing the command line: smsswd.exe /run: cmd /c xcopy.exe "\\x.x.x.x\Sources\ThinInst\*.*" C:\Thinstaller\ /E /D	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
!--------------------------------------------------------------------------------------------!	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
Expand a string: WinPEandFullOS	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
Executing command line: smsswd.exe /run: cmd /c xcopy.exe "\\x.x.x.x\Sources\ThinInst\*.*" C:\Thinstaller\ /E /D	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
[ smsswd.exe ]	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
PackageID = ''	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
BaseVar = '', ContinueOnError=''	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
ProgramName = 'cmd /c xcopy.exe "\\x.x.x.x\Sources\ThinInst\*.*" C:\Thinstaller\ /E /D'	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
SwdAction = '0001'	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
Set command line: Run command line	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
Working dir 'not set'	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
Executing command line: Run command line	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
Process completed with exit code 4	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
0 File(s) copied	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
Invalid drive specification	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
Command line returned 4	InstallSoftware	1/12/2016 8:27:40 AM	1048 (0x0418)
Process completed with exit code 4	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
The system cannot open the file. (Error: 00000004; Source: Windows)	TSManager	1/12/2016 8:27:40 AM	920 (0x0398)
