sprite
Version Not Compatible - HELP
hello,
I recently upgraded SCCM 2012 to SP@ and since I haven't been able to push and install the client.
The client ccmsetup log shows: Client version '5.00.8239.1000' is not compatible with the site 'BUR' version '5.00.7804.1400'
Not sure how to proceed to correct the problem. Do I un-install SP2 or upgrade the "site". IF so, how would I upgrade?
Thanks!
