MagnumVP
Surface Pro 3/4 Driver Importing
I have downloaded the Surface Pro 3 and 4 drivers from Microsoft's site https://www.microsoft.com/en-us/download/details.aspx?id=49498.
It was able to extract the zip file into \\server\sources\drivers\sourcefiles\SurfacePro4
When I import the drivers and select this root folder it only shows and imports about 12 drivers all System drivers from the System folder. I have verified that the drivers are there,
Folders with extracted drivers.
probably because the drivers are already imported and therefore duplicates, you can use jason sandys duplicate script to create a txt file in each folder of the driver pack before importing
