markm_sh
Deployment issue with Latitude E7270 from SCCM 2012 OSD
Hello all:
A couple of weeks ago I received a 7270 for deployment testing. My company currently runs SCCM 2012 SP1 (not R2/no CU's) with the ADK for Windows 8.0 and we deploy to a variety of Dell laptops including the 7240 and 7250. When I tried to boot the 7270 using our existing boot media it did not detect the network adapter.
I downloaded the latest WinPE driver pack from Dell, injected the drivers into our boot image, and still no luck. I then created a WinPE using the ADK for Windows 10. Booting from this image also resulted in the network adapter not being detected, but when I injected the Dell WinPE drivers manually it finally showed network connectivity.
Figuring the necessary network driver is definitely in the WinPE driver pack from Dell, I have tried several different tests to get the driver into our boot image for OSD to no avail.
Is anyone else testing the 7270 and having any luck?
I had a similar issue with an E7450 which would refuse to pick up an IP address when booting into WinPE from SCCM. I originally built the WinPE SCCM 2012 boot image using the integrated MDT 2013. Using SCCM I injected drivers from the Dell Driver Cab (http://en.community.dell.com/techcenter/enterprise-client/w/wiki/7938.latitude-e74507450-windows-7-driver-pack/) but got the same issue.
he resolution to this issue is the below:
1) Install Windows ADK (http://www.microsoft.com/en-gb/download/details.aspx?id=39982), selecting WinPE
2)Take the WinPE.wim file from the install directory (C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Windows Preinstallation Environment\amd64\en-us) and place in an easy to remember directory
3)Download the drivers direct from intel (https://downloadcenter.intel.com/download/23073/Network-Adapter-Driver-for-Windows-Server-2012-R2) and run the installer.
4)Extract the network drivers from the temporary folder that is created. You are looking for the NDIS63 and 64 folders
5)Copy these drivers to an easy to remember location
6)Using DISM mount WinPE and import the network drivers from the driver location
7)Unmount the WinPE Wim image, and from there import into SCCM 2012
8)Apply the Image to the relevant task sequence and boot
This should then solve your problems
http://robotrambling.blogspot.co.uk/2015/03/e7450-exit-out-when-loading-winpe.html
Hello all:
what version of ADK10?
I am also testing the E7270 and E7470 laptops in our SCCM 2012 R2 w/MDT 2013 environment. I am using the WinPE5.0 boot wim and have downloaded and injected the drivers from both Dell and Intel’s website but still no luck PXEing these models. It does not detect the network adapter. I have also grabbed the nic drivers off a working E7470 laptop running W7x64 Pro and uploaded that specific driver into SCCM and still nothing. We deploy W7x64 Enterprise so I don’t think the nic drivers are different.
I have tried what JTPort suggested in the above post and still nothing. Has anyone had any luck getting SCCM to see the nic drivers?
Thanks.
I finally got it working by injecting the I219-LM driver from Intel: https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Connections-CD Since I wasn't sure which driver would work I deleted all x32 and Linux folders and only imported the Winx64 drivers from these folders:PROXGB, PRO1000, PRO40GB, PLATFORM, NVMUupdatePackage, APPS. One of these folders contained the right driver but I'm not sure which one as I didn't have the time to thoroughly test each one. The bios also had to be changed to UEFI w/Legacy enabled, SATA on AHCI, Secure boot disabled and FastBoot set to Auto. This worked for both Latitude E7470 and E7270 models.
I am having a heck of a time with a Dell 7470. Struggling through UEFI and the Samsung NVMe PM951 M.2 drives. Been injecting drivers in new WinPE boot.wims like crazy and getting all sorts of errors and issues. Am injecting the I219-LM drivers into my latest boot image from the Intel 20_7_CD. BTW, I found those in PRO1000\Winx64\NDIS62\e1d62x64.inf. BIOS are set to UEFI w/Legacy, SATA RAID, Secure Boot disabled and Fastboot set to Auto.
Will be updating as I get things going.
So I am getting "Unable to read task sequence configuration disk." after the install reboots into WinPE. Here is the smsts.log;
<![LOG[LOGGING: Finalize process ID set to 1000]LOG]!><time="14:45:51.463+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="tslogging.cpp:1864">
<![LOG[==============================[ TSBootShell.exe ]==============================]LOG]!><time="14:45:51.479+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="bootshell.cpp:1061">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="14:45:51.479+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="util.cpp:966">
<![LOG[Debug shell is enabled]LOG]!><time="14:45:51.479+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="bootshell.cpp:1072">
<![LOG[Waiting for PNP initialization...]LOG]!><time="14:45:51.479+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="bootshell.cpp:60">
<![LOG[RAM Disk Boot Path: MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM]LOG]!><time="14:45:51.479+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:323">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:45:51.494+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:45:51.494+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:45:51.494+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (0)...]LOG]!><time="14:45:51.494+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:45:53.510+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:45:53.510+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:45:53.510+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (1)...]LOG]!><time="14:45:53.510+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:45:55.511+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:45:55.511+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:45:55.511+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (2)...]LOG]!><time="14:45:55.511+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:45:57.512+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:45:57.512+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:45:57.512+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (3)...]LOG]!><time="14:45:57.512+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:45:59.513+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:45:59.513+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:45:59.513+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (4)...]LOG]!><time="14:45:59.513+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:01.515+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:01.515+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:01.515+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (5)...]LOG]!><time="14:46:01.515+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:03.517+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:03.517+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:03.517+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (6)...]LOG]!><time="14:46:03.517+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:05.519+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:05.519+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:05.519+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (7)...]LOG]!><time="14:46:05.519+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:07.520+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:07.520+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:07.520+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (8)...]LOG]!><time="14:46:07.520+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:09.522+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:09.522+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:09.522+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (9)...]LOG]!><time="14:46:09.522+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:11.523+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:11.523+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:11.523+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (10)...]LOG]!><time="14:46:11.523+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:13.525+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:13.525+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:13.525+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (11)...]LOG]!><time="14:46:13.525+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:15.526+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:15.526+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:15.526+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (12)...]LOG]!><time="14:46:15.526+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:17.528+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:17.528+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:17.528+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (13)...]LOG]!><time="14:46:17.528+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:19.530+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:19.530+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:19.530+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (14)...]LOG]!><time="14:46:19.530+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:21.531+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:21.531+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:21.531+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (15)...]LOG]!><time="14:46:21.531+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:23.533+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:23.533+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:23.533+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (16)...]LOG]!><time="14:46:23.533+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:25.535+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:25.535+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:25.535+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (17)...]LOG]!><time="14:46:25.535+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:27.536+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:27.536+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:27.536+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (18)...]LOG]!><time="14:46:27.536+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:29.538+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:29.538+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:29.538+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (19)...]LOG]!><time="14:46:29.538+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:31.540+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:31.540+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:31.540+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (20)...]LOG]!><time="14:46:31.540+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:33.541+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:33.541+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:33.541+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (21)...]LOG]!><time="14:46:33.541+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[hMap != 0, HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentscope.cpp,493)]LOG]!><time="14:46:35.348+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="1004" file="environmentscope.cpp:493">
<![LOG[m_pGlobalScope->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,335)]LOG]!><time="14:46:35.348+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="1004" file="environmentlib.cpp:335">
<![LOG[this->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,553)]LOG]!><time="14:46:35.348+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="1004" file="environmentlib.cpp:553">
<![LOG[Executing command line: X:\windows\system32\cmd.exe /k]LOG]!><time="14:46:35.348+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="bootshell.cpp:866">
<![LOG[The command completed successfully.]LOG]!><time="14:46:35.360+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="bootshell.cpp:948">
<![LOG[successfully launched command shell.]LOG]!><time="14:46:35.360+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="bootshell.cpp:438">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:35.548+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:35.548+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:35.548+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (22)...]LOG]!><time="14:46:35.548+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:37.549+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:37.549+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:37.549+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (23)...]LOG]!><time="14:46:37.549+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:39.565+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:39.565+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:39.565+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (24)...]LOG]!><time="14:46:39.565+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:41.566+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:41.566+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:41.566+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (25)...]LOG]!><time="14:46:41.566+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:43.568+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:43.568+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:43.568+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (26)...]LOG]!><time="14:46:43.568+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:45.582+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:45.582+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:45.582+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (27)...]LOG]!><time="14:46:45.582+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:47.583+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:47.583+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:47.583+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (28)...]LOG]!><time="14:46:47.583+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[::GetVolumeNameForVolumeMountPointW( sDevicePath, szDeviceVolumeId, szDeviceVolumeId.size()), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,164)]LOG]!><time="14:46:49.585+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:164">
<![LOG[DevicePath::DeviceNamespaceWin32Path(sDevicePath, rsWin32Path), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\devicepath.cpp,120)]LOG]!><time="14:46:49.585+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="devicepath.cpp:120">
<![LOG[DevicePath::ArcToWin32Path(pszBootPath, rsLogicalPath), HRESULT=80070003 (e:\nts_sccm_release\sms\framework\tscore\bootsystem.cpp,112)]LOG]!><time="14:46:49.585+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootsystem.cpp:112">
<![LOG[ConvertBootToLogicalPath failed to convert 'MULTI(0)DISK(0)RDISK(0)PARTITION(3)\_SMSTASKSEQUENCE\WINPE\SOURCES\BOOT.WIM' (0x80070003). Retrying (29)...]LOG]!><time="14:46:49.585+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="configpath.cpp:39">
<![LOG[bGotPath, HRESULT=80070003 (e:\nts_sccm_release\sms\client\tasksequence\bootshell\configpath.cpp,42)]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="configpath.cpp:42">
<![LOG[ConvertBootToLogicalPath failed after retries. Giving up.]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="3" thread="88" file="configpath.cpp:42">
<![LOG[GetConfigPathFixedDisk(sArcPath, sWinPEFolder), HRESULT=80070003 (e:\nts_sccm_release\sms\client\tasksequence\bootshell\configpath.cpp,347)]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="configpath.cpp:347">
<![LOG[Failed to find the current TS configuration path]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="3" thread="88" file="configpath.cpp:397">
<![LOG[ConfigPath::FindConfigPath(sConfigPath), HRESULT=80070003 (e:\nts_sccm_release\sms\client\tasksequence\bootshell\bootshell.cpp,551)]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="bootshell.cpp:551">
<![LOG[Failed to find the configuration path.
The system cannot find the path specified. (Error: 80070003; Source: Windows)]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="3" thread="88" file="bootshell.cpp:551">
<![LOG[Execution failed with error 80070003.]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="3" thread="88" file="bootshell.cpp:709">
<![LOG[hMap != 0, HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentscope.cpp,493)]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="environmentscope.cpp:493">
<![LOG[m_pGlobalScope->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,335)]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="environmentlib.cpp:335">
<![LOG[this->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,553)]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="environmentlib.cpp:553">
<![LOG[::RegOpenKeyExW (HKEY_LOCAL_MACHINE, sKey.c_str(), 0, KEY_READ, &hSubKey), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\utils.cpp,810)]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="utils.cpp:810">
<![LOG[RegOpenKeyExW is unsuccessful for Software\Microsoft\SMS\Task Sequence]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="2" thread="88" file="utils.cpp:810">
<![LOG[GetTsRegValue() is unsuccessful. 0x80070002.]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="2" thread="88" file="utils.cpp:843">
<![LOG[End program: ]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="bootshell.cpp:731">
<![LOG[Finalizing logging from process 1000]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="tslogging.cpp:2110">
<![LOG[Finalizing logs to root of first available drive]LOG]!><time="14:46:51.587+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="tslogging.cpp:1952">
<![LOG[successfully finalized logs to X:\SMSTSLog]LOG]!><time="14:46:51.602+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="tslogging.cpp:2009">
<![LOG[Cleaning up task sequencing logging configuration.]LOG]!><time="14:46:51.602+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="tslogging.cpp:907">
<![LOG[TS::Environment::SharedEnvironment.isInitialized() == true, HRESULT=80004005 (e:\nts_sccm_release\sms\framework\tscore\tslogging.cpp,694)]LOG]!><time="14:46:51.602+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="tslogging.cpp:694">
<![LOG[TS environment is not initialized]LOG]!><time="14:46:51.602+480" date="03-15-2016" component="TSBootShell" context="" type="3" thread="88" file="tslogging.cpp:694">
<![LOG[hMap != 0, HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentscope.cpp,493)]LOG]!><time="14:46:51.602+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="environmentscope.cpp:493">
<![LOG[m_pGlobalScope->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,335)]LOG]!><time="14:46:51.602+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="environmentlib.cpp:335">
<![LOG[this->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,553)]LOG]!><time="14:46:51.602+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="environmentlib.cpp:553">
<![LOG[!sTSMDataPath.empty(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\resolvesource.cpp,1436)]LOG]!><time="14:46:51.602+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="88" file="resolvesource.cpp:1436">
<![LOG[There is no TSM local data path being set]LOG]!><time="14:46:51.602+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="88" file="utils.cpp:2463">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="14:46:51.711+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="1004" file="commandline.cpp:229">
<![LOG[set command line: "X:\sms\bin\x64\TsProgressUI.exe" /Register:WinPE]LOG]!><time="14:46:51.711+480" date="03-15-2016" component="TSBootShell" context="" type="0" thread="1004" file="commandline.cpp:732">
<![LOG[Executing command line: "X:\sms\bin\x64\TsProgressUI.exe" /Register:WinPE]LOG]!><time="14:46:51.711+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="commandline.cpp:828">
<![LOG[==========[ TsProgressUI started in process 780 ]==========]LOG]!><time="14:46:51.758+480" date="03-15-2016" component="TsProgressUI" context="" type="1" thread="868" file="winmain.cpp:330">
<![LOG[Command line: "X:\sms\bin\x64\TsProgressUI.exe" /Register:WinPE]LOG]!><time="14:46:51.758+480" date="03-15-2016" component="TsProgressUI" context="" type="0" thread="868" file="winmain.cpp:332">
<![LOG[Registering COM classes]LOG]!><time="14:46:51.758+480" date="03-15-2016" component="TsProgressUI" context="" type="1" thread="868" file="winmain.cpp:187">
<![LOG[sbModulePath = X:\sms\bin\x64\TsProgressUI.exe]LOG]!><time="14:46:51.773+480" date="03-15-2016" component="TsProgressUI" context="" type="1" thread="868" file="tsprogressuiclass.cpp:625">
<![LOG[unregistering class objects]LOG]!><time="14:46:51.773+480" date="03-15-2016" component="TsProgressUI" context="" type="1" thread="868" file="winmain.cpp:495">
<![LOG[shutdown complete.]LOG]!><time="14:46:51.773+480" date="03-15-2016" component="TsProgressUI" context="" type="1" thread="868" file="winmain.cpp:512">
<![LOG[Process completed with exit code 0]LOG]!><time="14:46:51.773+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="commandline.cpp:1124">
<![LOG[successfully registered TS Progress UI.]LOG]!><time="14:46:51.773+480" date="03-15-2016" component="TSBootShell" context="" type="1" thread="1004" file="utils.cpp:3046">
It was seemingly unrelated, maybe. But I applied the fix outlined here;
https://support.microsoft.com/en-us/kb/3143760
Step 1: Preparation
  1. Extract the contents of the hotfix. For example, extract the contents to the %userprofile%\downloads folder.
  2. Start an elevated “Deployment and Imaging Tools Environment” command prompt.
Step 2: Prepare Windows PE
Create the Windows PE customization working directory, and then mount the image file. To do this, type the following commands, and then press Enter after each command:
copype.cmd amd64 c:\WinPE_amd64
dism /mount-wim /wimfile:C:\WinPE_amd64\media\sources\boot.wim /index:1 /mountdir:C:\WinPE_amd64\mount
Note The copype.cmd amd64 c:\WinPE_amd64 command is not required for an existing boot image.
For information about dism commands, see DISM Image Management command-line options.
Step 3: Save schema.dat state
Back up the permissions that are applied to the existing schema.dat file before you replace it. To back up the file, type the following command, and then press Enter:
icacls c:\WinPE_amd64\mount\Windows\System32\schema.dat /save "%temp%\AclFile"
Step 4: Update the schema.dat file
To replace the schema.dat file that has the updated version, you must take ownership of the file and grant permissions to the local administrators group. To do this, type the following commands, and then press Enter after each command:
takeown /F c:\WinPE_amd64\mount\Windows\System32\schema.dat /A
icacls c:\WinPE_amd64\mount\Windows\System32\schema.dat /grant BUILTIN\Administrators:(F)
xcopy "%userprofile%\Downloads\schema-x64.dat" c:\WinPE_amd64\mount\Windows\System32\schema.dat /Y
Step 5: Reset permissions and ownership
When the schema.dat file is replaced, the permissions saved in step 5 must be restored by running the following commands:
icacls c:\WinPE_amd64\mount\Windows\System32\schema.dat /setowner "NT SERVICE\TrustedInstaller"
icacls c:\WinPE_amd64\mount\Windows\System32\ /restore "%temp%\AclFile"
Step 6: Commit Windows PE changes
Commit the changes to the boot.wim file. To do this, type the following command, and then press Enter:
dism /unmount-wim /mountdir:C:\WinPE_amd64\mount /Commit
Step 7: Add a boot image
Note This step is not required for an existing boot image.
Add the boot images by using the methods that are described in the following TechNet articles:
Step 8: Update distribution points
Update the boot images by using the methods that are described in the following TechNet articles:
Specify where the boot image is distributed (System Center 2012 Configuration Manager)
Distribute boot images to a distribution point (current branch)
And now I can get WinPE to start the process, on a VMware copy of the master image, but alas, hit a snag;
Task Sequence: Image capture wizard has failed with the error code (0x800704CF)
Working on getting permissions sorted out. Trying it out on the actually hardware now.
