hlee
How to upgrade SCCM 2012 R2 SP1 to SCCM 1511 and MDT 2013?
Here's my current setup:
SCCM 2012 R2 SP1 with MDT 2013 and ADK 8.1, using UDI for task sequence. I would like to upgrade to SCCM 1511 with MDT 2013 Update 2, with ADK 10. In what sequence should I go to achieve this?
1. Uninstall ADK 8.1 and install ADK 10?
2. Install SCCM 1511 in-place upgrade
3. Install MDT 2013 Update 2?
4. Recreate Task Sequence with MDT 2013 Update 2, UDT task sequences?
Thanks!
install the ADK RTM, otherwise you will get into a lot of problems.
Regarding the point 4, I guess you have to create new boot images, packages and settings.
issues with ADK:
https://www.windows-noob.com/forums/topic/13626-sccm-lab-build-and-capture-on-vmware/
read the last post...
Issues with build and capture (workaround):
https://social.technet.microsoft.com/Forums/en-US/46052503-6954-4058-b17b-08499e1e0263/client-will-not-initialise?forum=ConfigMgrCBOSD
Have fun! :)
And, if you have drivers in the bootimages you should export them first so you have some clue of what to import in the new bootimages...
http://www.snowland.se/2015/09/03/export-import-boot-image-drivers-needed-before-adk-upgrade/
I have been unable to update my default boot images since updating.
I think it's because of a driver but I've removed the driver from SCCM since and it must be still wanting it.
I have no idea what it wants. I've been trying to find a way to tell it to just skip the bloody driver but nothing seems to work for me.
