bscull
presented with a dialog box to choose a preferred language
Hi all
Sorry if this has been asked before, but my ninja googling skills have let me down.
I have been following the below how-to trying to customize deploying Language packs via a MDT 2012/SCCM 2012 SP1
https://www.windows-noob.com/forums/topic/3251-customising-windows-7-deployments-part-4/
I ran into a number of problems where the ZIPatches_DISM.log file was filling up the X: Drive (scratch disk) and I could not get it to relocated to the OS partition, but once I increased the scratch disk size to 256mb, that resolved that problem. The log file was close to 200mb (don't know why)
The issues I am having now, is the Language Pack (fr-FR) is installing but once Windows starts I am presented with a dialog box to choose a preferred language. Also the Time zone, keyboard etc. are not been applied.
I am using the below Unattend.xml and CustomSetting.ini file for my deployment. I am also setting the unattended Variable in the Task Sequence just before the MDT install Language Pack Offline.
Has anyone got any ideas how I can resolve this?
Thanks for all your help!!!
Task Sequence Variable set before MDT install language pack offlice
OSDUILanguage=fr-FR
OSDTimeZone= Romance Standard Time
OSDInputLocale= 040c:0000040c
OSDSystemLocale=fr-FR
OSDUILanguageFallback= en-US
OSDUserLocale= fr-FR
OSD_Variables_added.xml (unattend.xml file)
<?xml version="1.0" encoding="utf-8"?>
<unattend xmlns="urn:schemas-microsoft-com:unattend">
<settings pass="oobeSystem">
<component name="Microsoft-Windows-International-Core" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State"xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<InputLocale>%OSDInputLocale%</InputLocale>
<SystemLocale>%OSDSystemLocale%</SystemLocale>
<UILanguage>%OSDUILanguage%</UILanguage>
<UILanguageFallback>%OSDUILanguageFallback%</UILanguageFallback>
<UserLocale>%OSDUserLocale%</UserLocale>
</component>
</settings>
<cpi:offlineImage cpi:source="wim://xxxxx/osd/source-files/windows%207%20ent%20x64/sources/install.wim#Windows 7 ENTERPRISEN" xmlns:cpi="urn:schemas-microsoft-com:cpi" />
</unattend>
CustomSetting.ini
[settings]
Priority=Default
Properties=MyCustomProperty
[Default]
OSInstall=Y
SkipCapture=YES
SkipAdminPassword=NO
SkipProductKey=YES
0 answers to this question
