firstcom
MDT Questions
Hey all!
I'm pretty new to using MDT alongside SCCM and there's a few objectives that I'd really like to figure out.
1. How can you better customize options within a MDT "Install Software" option? For example, if I wanted to create an option where the person selected what department a PC is going to belong to, I'd like to have it automatically check or uncheck associated software. I previously did this within SCCM with task sequence variables.
2. Likewise, I'd like this sequence to be able to determine which installers to use based on whether or not the build is x86 or x64. I've noticed a few options for this in the "Software and Groups" options, and suspect my answer lies there but want to be sure.
3. With my old task sequence in SCCM, I had to choose to ignore errors and proceed anyway if an install fails for a couple of items. How do I achieve this with MDT?
4. I followed the MDT install guide here on Windows-noob to get everything up and running - is there a good guide out there for really digging deep and customizing MDT for some of the more common situations, like the items I'm requesting?
Thanks all!
