Config_Mgr_noob Posted March 30, 2016 Report post Posted March 30, 2016 Hi all, I am trying to deploy my TS to existing imaged PCs in attempt to install several applications and to give my users a warning screen informing them that this installation is about to occur. I have tried the steps from anyweb in this other forms but no avail. I keep receiving the below error message. I also added the Toolkit package pointing to MDT in case I am missing any files. And the Task Sequence package I have listed below consist of only the ServiceUI.exe and the .hta file. Is even possible to do what I am describing to give my users a warning prior to deployments? If not, is there any other methods to warn my users before the installations occur? Not sure what I'm overlooking but any help would be appreciated. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted March 31, 2016 Report post Posted March 31, 2016 where is the warning.hta file placed ? try hard coding the path to it eg: C:\Windows\temp\warning.hta Quote Share this post Link to post Share on other sites More sharing options...
Config_Mgr_noob Posted March 31, 2016 Report post Posted March 31, 2016 I placed the .hta file along with the serviceUI.exe (x64) package alone. I tried your suggestion to hard code the path to C:\Windows\temp\warning.hta but no avail again. I received again the below. I'm not sure if it might have to do with the serviceUI.exe file I am using? I also took a screenshot of the cmd line I used in my TS. Quote Share this post Link to post Share on other sites More sharing options...
Config_Mgr_noob Posted April 5, 2016 Report post Posted April 5, 2016 Is there any new info or direction you can supply me with? I'm still not sure if this method is possible to deploy to devices that are not being imaged? If so, do I only copy the ServiceUI.exe file or the full "x64" folder content from the MDT folder? Quote Share this post Link to post Share on other sites More sharing options...
