Phred
Having trouble visualizing MDT and SCCM
Did you re-distribute the package to your DP after making the changes?
The D Drive is always listed as the Primary Drive as the UDI runs in Windows PE (the WinPE partition takes letter C).
Disable the "Set Variable for Drive Letter" step in the Task Sequence
And make sure your variable in your Partition and Apply Operating System steps is consistent usually OSDisk. The task sequence will then ensure (post WinPE) that the image is applied to C.
You'll get there in the end with UDI's, it took me ages to puzzle all the pieces together. There is next to zero documentation on this direct from Microsoft which doesnt help matters.
