nizar
autodesk inventor 2009 deployement problem
Hi
Please i want help
I distributed autodesk inventor pro 2009 with sccm 2007 SP2 RTM but software cannot be installed .
In cache of client i can see a folder but when i explore this folder i don't found all files(messing files)i don't know if that a network problem because i tested with 2 different network but always same problem.
thank you for help
8 answers to this question
Hi
software Runed from Distribution point after that i see on sccm that the software is distributed and installed but in the client machine i see:Assigned Program About to Run(See Attachment Photo)
and after no thing program cannot be installed.
please have a solution.
thank you very much.
Hi
I Runed software from Distribution point another time and the application is installed with success.
thank you for your help.
I have another question please: can i deploy application to a workgroup computer, if yes how can i deploy sccm client to this station.
thank you
