vekh
Offline installation failed with error code 0x80070002
Hello.
I have a problem with offline windows 7 x86 deployment (USB full media/offline media). During Apply Operating System step SCCM returns error 0x80070002 (look at the attached picture). Details in smsts.log
What I've tried:
1) Downloading original *.wim file manually from DS, dividing it into 2 *.swm files with the same size as orignal and replacing them with the files on USB drive
2) Copying original *.wim file from computer partition during online deployment - rest as in 1.
3) Inserting untouched *.wim file downloaded from DS/copied from online deployment
4) Seting correct date/time in bios
5) Disk cleaning (diskpart)
6) Size comparison
7) Applying *.wim file manually - it works
Nothing helps <_< Most of solutions concerns online deployments and errors are related to applications installation not system itself. I have no idea what's going on. Installation runs flawlessly during online deployment.
smsts.logFetching info...
Edited by vekh
