clush
Running Powershell Script in Task Sequence Error
I am trying to run a powershell script in a task sequence where it takes the mac address and assigns a computer name from a text file. Everytime I run it i get a 0x80004005 error.
I have tried both running it as a powershell script as well as run a command line and get the same error. I did create a package of the script as not a program.
In the task sequence I pointed it at the package and the script name and I assigned it as bypass. I left the parameters section blank I am not sure if I should have added anything in here such as variables.
I have attached the code in a jpeg. Please keep in mind I am not a programmer and I am not sure what they mean by variables.
BTW: The was tested and it runs. Only the last couple of lines couldn't be tested as it has to go into a task seq.
Thank you...
3 answers to this question
