johnli Posted June 17, 2016 Report post Posted June 17, 2016 Hi! Need some help, stuck witch this issue. ISSUE : After I hit F12, the client downloads the .wim from the correct server. But when the image is downloaded, it take very long (5min) to come at the Task Sequence Wizard When I check the smsts.log, then I see that the client want's to connect to a DP in a non-trusted domain.That server is not available, and after a few tries the client is going for the appropriate DP. The client is in the correct boundarie, en IP Helper refers to the correct server. Any tips, suggestions ? Quote Share this post Link to post Share on other sites More sharing options...
GarthMJ Posted June 17, 2016 Report post Posted June 17, 2016 What are you Boundaries? IP Ranges, IP Subnet? AD Sites? Do you have fallback enabled for this deployment? Quote Share this post Link to post Share on other sites More sharing options...
johnli Posted June 17, 2016 Report post Posted June 17, 2016 Boundaries er IP basert and NO fallback Quote Share this post Link to post Share on other sites More sharing options...
