Deploy application & registry key using .bat
I have a simple application that I need to install, another old one which I need to uninstall it first and I need to make a registry change along with it. I chose to batch the process, and here’s what I have:
Uninstall:
msiexec /uninstall {19ED22B4-4058-4BB6-AFBB-357D6383534E} /quiet
Install:
Msiexec /q /i "\\fileserver\Source$ \Laserform_Intranet_Client_2.3\LFormInetClient.msi" SQLSERVER="Server" WEBSERVER="http://Server/LformInet/Default.aspx" DMSID="MHODMA"
Update registry key:
regedit.exe /s "%~dp0change.reg"
The two registry keys looks like this:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Laserform\LFormInet]
"SQL Server"="Server"
"URL"="http://Server/LformInet/"
"DBTYPE"="SQL"
"SQL ServerLive"="Server"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Laserform\LFormInet]
"DBTYPE"="SQL"
"ClientVer"="5.1.33"
In the end the .bat file should look like this:
REM Check if 32-bit command-prompt launched on 64-bit OS
IF "%PROCESSOR_ARCHITEW6432%"=="AMD64" SET REGPATH=%SystemRoot%\SysWOW64\REGEDIT.EXE
%REGPATH% /s "%~dp0change.reg"
So from what I understand so far (at least this is what someone explain it to me) it is possible that the registry edit won’t work if run through ConfigMgr though for two reasons. First, you are trying to modify a value specific to a user and second because you are trying to modify a value in the 32-bit section of the Software hive.
Anyone have other experiences using something like this ?
Thank you.
  • 5 weeks later...
Not a problem, have you tried doing this to see if it works. I usually use a "Reg add" command to put reg keys into a machine. You can force "reg Add" to place it in the wow6432 hive. By default it places it in the 64bit hive, but using a "/reg:64" will ensure the entries goes into the 32bit hive
correct. This one is tricky but heres one way to do this:
1 - Create a "Application" or "Package" that runs for the user (but with administrative rights), I had a scenario where i needed to send out a reg key to HKCU so created a Application, which applies a batch file. The application is set to install for user therefore works for every user who logs onto the machine (as the application detection method checks HKCU if the key exists, therefore anybody who logs on will get the key if they dont already have it)
You could also use Orca to edit the MSI file and insert those regkeys into it, although thats a bit more involving.
You should check out the PS App Deploy Toolkit. It makes doing things like this a lot simpler. I do agree though, an MST to do the reg keys would do this very well.
