marcinw
Problem with Broadcom Netxtreme drivers in WinPE 10 x64 on HP XW4600
Dear Forum,
I have problem deploying HP XW4600 workstation with SCCM. I'm using WinPE 10 x64 from MDT2013.
I was following this procedure to find out card driver (I also tried driver from running WIndows 7x64):
https://www.niallbrady.com/2011/08/31/missing-nic-driver-in-winpe-boot-image-no-problem/
So my card is definitely:
Broadcom NetXtreme Gigabit Ethernet
PCI\VEN_14E4&DEV_167B&SUBSYS_1308103C
I took driver for x64 Desktop/Mobile/Server (x64) version 17.2.0.2 from:
https://www.broadcom.com/support/ethernet-nic-netxtreme-i-desktop-mobile
When I load the driver with drvload b57nd60a.inf
it says that driver was loaded fine, then I do the:
wpeutil initializeNetwork
followed by
ipconfig
but cannot get IP address from the server.
I've also tried: HP Client Windows PE 10 x64 Driver Pack
from: http://ftp.hp.com/pub/caps-softpaq/cmit/softpaq/WinPE10.html
without success...
In the past I've been using 32bit WinPE and these XP workstations were installing fine.
Could You please help me to detect and insert correct driver ?
Dear Forum,
followed by
ipconfig
without success...
