OliAdams Posted September 7, 2016 Report post Posted September 7, 2016 I am seeing a lot of problems with installing my management point. The log file is attached. I have tried removing and reinstalling with the same problems. A small section is shown here. Property(S): DialogBox_Title = ConfigMgr Management Point Setup Property(S): WelcomeDialog_Info = This will install the ConfigMgr Management Point. Property(S): InstallDialog_Title = Install Property(S): InstallDialog_SubTitle = The product is now ready to install Property(S): InstallDialog_Info = Click Next to proceed. Property(S): ProgressDialog_Title = Please Wait Property(S): ProgressDialog_SubTitle = Setup is configuring your system. Property(S): CompleteDialog_Title = Setup Complete Property(S): CompleteDialog_SubTitle = Setup has finished updating your system. Property(S): CompleteDialog_Info = Setup was successful. Property(S): UserExitDialog_Title = Setup Aborted Property(S): UserExitDialog_SubTitle = Setup was cancelled Property(S): UserExitDialog_Info = The ConfigMgr Management Point setup was cancelled. Property(S): InstallErrorDialog_Title = Setup Aborted Property(S): InstallErrorDialog_SubTitle = Setup failed Property(S): InstallErrorDialog_Info = Setup encountered an error and could not continue. Any advice is appreciated. mpmsi.log Quote Share this post Link to post Share on other sites More sharing options...
GarthMJ Posted September 7, 2016 Report post Posted September 7, 2016 That looks perfect. Why do you think there is a problem. Quote Share this post Link to post Share on other sites More sharing options...
OliAdams Posted September 7, 2016 Report post Posted September 7, 2016 it is this part. Plus I get lots of messages in the monitoring node as follows. Site Component Manager failed to install this component, because the Microsoft Installer File for this component (bgbisapi.msi) could not install. Site Component Manager failed to install this component, because the Microsoft Installer File for this component (mp.msi) could not install. I thought it might be related to these lines here: Property(S): UserExitDialog_Title = Setup Aborted Property(S): UserExitDialog_SubTitle = Setup was cancelled Property(S): UserExitDialog_Info = The ConfigMgr Management Point setup was cancelled. Property(S): InstallErrorDialog_Title = Setup Aborted Property(S): InstallErrorDialog_SubTitle = Setup failed Property(S): InstallErrorDialog_Info = Setup encountered an error and could not continue. Quote Share this post Link to post Share on other sites More sharing options...
GarthMJ Posted September 7, 2016 Report post Posted September 7, 2016 Those are NOT error, they are MSI properties. Your problem is that there is a newer version of the CM client installed on this computer. Quote Share this post Link to post Share on other sites More sharing options...
OliAdams Posted September 7, 2016 Report post Posted September 7, 2016 Ok, I was confused before now I dont know how to explain it. This is on the site server. What do I need to do now? Quote Share this post Link to post Share on other sites More sharing options...
GarthMJ Posted September 7, 2016 Report post Posted September 7, 2016 What CM client version do you have on this server? Quote Share this post Link to post Share on other sites More sharing options...
