The Capture Network Settings task in a ConfigMgr 2007 OSD Task Sequence may not properly capture DNS & WINS settings on teamed NICs
When using the "Capture Network Settings" task in a Configuration Manager 2007 (SCCM 2007) OSD Task Sequence on a PC that has teamed NICs, not all of the settings of the NIC may be captured properly. This mainly applies to DNS and WINS settings that are set statically. In these cases the settings are not captured and instead are set to obtain from DHCP when the network settings are restored via the "Apply Network Settings" task.
http://blogs.technet.com/configurationmgr/archive/2009/11/30/the-capture-network-settings-task-in-a-configmgr-2007-osd-task-sequence-may-not-properly-capture-dns-wins-settings-on-teamed-nics.aspx
0 answers to this question
