Siroj
Set WinPE resolution without MDT integration
I know that it's possible to automatically set WinPE resolution by setting the X and YResolution variable when using MDT integration. Using an unsupported (low) value results in automatic detection.
We want to incorporate the same solution, but without MDT integration. I can't find a solution to this, so my question is if this is even possible?
I won't mind adding some custom variables or making other customization's.
