lowerym
Dependency problems
Hi
I and currently setting up Adobe Acrobat DC2016 as a application.
This requires a setup file to be run before the main installation file can be run.
I have set this up as a script to run as a dependency but it does not work.
I am new to SCCM so any assistance would be most welcome.
I have attached the AppEnforce log if this may help.
Hey,
Our application for deploying Adobe Acrboat DC is as follows:
We have one Application with two Deployment Types
We have the msi installer set as priority 1 (msi) with a installation command msiexec /i "AcroPro.msi" TRANSFORMS="AcroPro.mst" /qb
We then have the setup.exe as priority 2 (script) with installation command "setup.exe" and have set the msi as the dependancy.
Both have user experience set set to Install for system, Weather or not a user is logged on and Hidden.
