Flap_Kebap
After hotfix KB3186654 on SCCM 1606, PXE not working
Hi, I have upgrade my environment (one primary server 7 distribution point, all server are server 2012 R2 standard) to Version 1606 Console version: 5.08412.1307 site version 5.0.8412.1000. Only after that my Eufi and legacy boot doesn't work any more,
Error message on y distribution point is:
RequestMPKeyInformation: Send() failed. SMSPXE 10/5/2016 1:09:38 PM 2920 (0x0B68)
Failed to get information for MP: http://servername. 80004005. SMSPXE 10/5/2016 1:09:38 PM 2920 (0x0B68)
reply has no message header marker SMSPXE 10/5/2016 1:09:38 PM 2920 (0x0B68)
PXE::MP_LookupDevice failed; 0x80004005 SMSPXE 10/5/2016 1:09:38 PM 2920 (0x0B68)
Failed to send status message (80004005) SMSPXE 10/5/2016 1:09:38 PM 2920 (0x0B68)
Failed to send the status message SMSPXE 10/5/2016 1:09:38 PM 2920 (0x0B68)
PXE::MP_ReportStatus failed; 0x80004005 SMSPXE 10/5/2016 1:09:38 PM 2920 (0x0B68)
PXE Provider failed to process message.
Unspecified error (Error: 80004005; Source: Windows) SMSPXE 10/5/2016 1:09:38 PM 2920 (0x0B68)
What have I done:
untick the enable PXE checkbox on the distribution point. Answer yes that you want to remove the Windows Deployment service.
remove boot images from your distribution point
After 5 minutes delete %windir%\temp
check with server manager. If WDS is done uninstalling there is a reboot pending. Reboot.
check if the remote install folder is located on your system. If it is delete it. If it fails to delete due to permission issues with the SMSTempBootFiles path, delete all folders except that one and then rename the remote install folder something else. reboot
Add the PXE point again by checking the box on the distribution point properties. Check the distrmgr.log and see if the remote install folder reappears..
Replicate the boot image to the DP again.
After that create a new Boot image with the latest ADK 10 version and distribute it to the distribution point
But still the same error, have somebody an idea?
Thanks a lot already..
It's solved now on our site. Some component could not update. SO we have remove the role 'Management Point' from out Primary server and wait 15 min.
After that we assign to role again and it works now. (als in the time that we are working on it we had turn of the firewall and the anti virus of Primairy and distribution point)
Hopefully it will helps you also.
  On 10/11/2016 at 11:30 PM, jcreaves9987 said:
I am having the exact same problem. Have you had any luck with a solution?
