Windows 10 Enterprise 1607 x64 CB (KMS Product Key)
I am unable to figure out how to create a task sequence that deploys Win10 using OSDComputerName.
Here is what I am doing:
Create Hyper-V VM
Install Windows 10
Run Windows Update
System is NOT joined to a domain
Use capture media and import as new OS image
Create task sequence; I have tried moving around the 'Set Task Sequence Variable' but nothing seems to work
PXE boot and run task sequence
Enter something like 'OSDTEST' when prompted for 'OSDComputerName'
The result is a system that joins the domain with a name like MININT-XXXXXXX.
Other tidbits:
There is nothing in the C:\Windows\Panther\Unattend folder. I believe there is supposed to be an Unattend.xml file there.
My task sequence includes a few other customizations including installing the SCCM Client and a couple of applications. All of these other things work great.
SCCM 2012 R2 SP1 CU3 (5.0.8239.1403)
Create Hyper-V VM
Install Windows 10
Run Windows Update
Other tidbits:
smsts.logFetching info...
