cfreeman21
Help Getting Parameter to work... Works if hardcoded
If you put in the Name for Software Update Group and the Collection ID the Main query works I need help getting the parameter to work. Thanks!
Main Query:
declare @SUG VARCHAR(50);
declare @COLID VARCHAR(8);
declare @CI_ID int;
select @CI_ID = CI_ID
from CI_ConfigurationItems
where CIType_ID=9 and CI_UniqueID=(select CI_UniqueID as AuthListID from v_AuthListInfo
Where Title=@SUG)
select Status=sn.StateName, StatusNumber=(CASE WHEN StateName='Compliant' THEN 1 WHEN StateName='Non-Compliant' THEN 3 ELSE 2 END), cs.NumberOfComputers, PercentOfComputers=convert(float, isnull(cs.NumberOfComputers, 0)*100.00) / isnull(nullif(cs.NumTotal, 0), 1)
  from (select CI_ID, NumTotal, [0]=NumUnknown, [1]=NumPresent+NumNotApplicable, [2]=NumMissing
   from v_UpdateSummaryPerCollection
      where CI_ID=@CI_ID and CollectionID=@COLID
    ) cnt
    unpivot (NumberOfComputers for [Status] in ([0], [1], [2])) cs
    left join v_StateNames sn on sn.TopicType=300 and sn.StateID=cs.Status
  where cs.NumberOfComputers>0
  order by StatusNumber
Query for SUG Paramter:
SELECT     CI_UniqueID, Title
FROM         v_AuthListInfo
WHERE     Title LIKE '%Compliance%' OR Title LIKE '%Software Updates%'
ORDER BY Title
Query for COLID Parameter:
SELECT DISTINCT c.CollectionID,
                c.CollectionName
FROM v_UpdateSummaryPerCollection c
WHERE (CollectionName LIKE '%Patching Group%' OR
c.CollectionName LIKE '%Compliance%' OR
c.CollectionName LIKE '%Server Patching%' OR
c.CollectionName LIKE '%Approved Patching%')
ORDER BY c.CollectionName
8 answers to this question
Hard Coded main Query:
DECLARE @SUG varchar(50);
DECLARE @COLID varchar(8);
DECLARE @CI_ID int;
SET @SUG = 'Software Updates | Servers | 2016'
SET @COLID = 'A1200602'
SELECT
  @CI_ID = CI_ID
FROM CI_ConfigurationItems
WHERE CIType_ID = 9
AND CI_UniqueID = (SELECT
  CI_UniqueID AS AuthListID
FROM v_AuthListInfo
WHERE Title = @SUG)
SELECT
  Status = sn.StateName,
  StatusNumber = (CASE
    WHEN StateName = 'Compliant' THEN 1
    WHEN StateName = 'Non-Compliant' THEN 3
    ELSE 2
  END),
  PercentOfComputers = CONVERT(float, ISNULL(cs.NumberOfComputers, 0) * 100.00) / ISNULL(NULLIF(cs.NumTotal, 0), 1)
FROM (SELECT
  CI_ID,
  NumTotal,
  [0] = NumUnknown,
  [1] = NumPresent + NumNotApplicable,
  [2] = NumMissing
WHERE CI_ID = @CI_ID
AND CollectionID = @COLID) cnt
UNPIVOT (NumberOfComputers FOR [Status] IN ([0], [1], [2])) cs
LEFT JOIN v_StateNames sn
  ON sn.TopicType = 300
  AND sn.StateID = cs.Status
WHERE cs.NumberOfComputers > 0
ORDER BY StatusNumber
Both Parameters are just Pulling Available Values Get Values from a query
I hate to say it but this doesn't answer my questions.
It will be faster for me to fix it that keep bounce back and forth. Send me your RDL. I need to know what version of SSRS you have and what you are using to edit the RDL.
As an aside and completely self promotion. I wrote a book on reporting that will walk you though all the steps to create great reports. https://www.amazon.com/System-Configuration-Manager-Reporting-Unleashed/dp/0672337789/
