Kinom Posted December 7, 2009 Report post Posted December 7, 2009 Ho all, I have a problem using USMT 4.0 in SCCM On my virtual environment it works fine , now I am trying to implement it on our existing infrastructure and I receive the following error 80070002. 0, HRESULT=80070002 (e:\nts_sms_fre\sms\client\osdeployment\osdusmt\userstateaction.cpp,95) VerifyIfPreLonghornBinary(sUsmtBinary, m_bUSMTPreLonghorn), HRESULT=80070002 (e:\nts_sms_fre\sms\client\osdeployment\osdusmt\userstateaction.cpp,523) SetUSMTBinary(), HRESULT=80070002 (e:\nts_sms_fre\sms\client\osdeployment\osdusmt\userstateaction.cpp,955) usmAction.Init(::GetCommandLineW()), HRESULT=80070002 (e:\nts_sms_fre\sms\client\osdeployment\osdusmt\main.cpp,235) Invoking ReleaseSource on USMTPackagePath D:\_SMSTaskSequence\Packages\F010013C Entering ReleaseSource() for D:\_SMSTaskSequence\Packages\F010013C reference count 1 for the source D:\_SMSTaskSequence\Packages\F010013C before releasing Delete source directory D:\_SMSTaskSequence\Packages\F010013C IsUsmtPreLonghorn failed (0x80070002). UserStateMigrationAction::GetUSMTBinary failed (0x80070002). Failed to initlialize, (0x80070002) Released the resolved source D:\_SMSTaskSequence\Packages\F010013C OSDMigrateUserState finished: 0x80070002 I deed already what Peter told me but it wont work. What am Im doing wrong? Quote Share this post Link to post Share on other sites More sharing options...
0 Peter van der Woude Posted December 7, 2009 Report post Posted December 7, 2009 I saw this error before... I don't know what causes this error, but I do know that pointing the package specifically to or x86 or x64 works arround it... Quote Share this post Link to post Share on other sites More sharing options...
0 Kinom Posted December 7, 2009 Report post Posted December 7, 2009 I will give it a try Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted December 7, 2009 Report post Posted December 7, 2009 take a look at this post Kinom http://social.technet.microsoft.com/Forums/en-US/configmgrosd/thread/feee79b7-6869-4df0-848b-0d6076f3bdfb once you have, try what is suggested there and see what happens, if it helps then i want you to tell us how you are doing this, i'm trying to find out why this is happening and so far, no answers.. Quote Share this post Link to post Share on other sites More sharing options...
0 Kinom Posted December 8, 2009 Report post Posted December 8, 2009 take a look at this post Kinom http://social.technet.microsoft.com/Forums/en-US/configmgrosd/thread/feee79b7-6869-4df0-848b-0d6076f3bdfb once you have, try what is suggested there and see what happens, if it helps then i want you to tell us how you are doing this, i'm trying to find out why this is happening and so far, no answers.. I deed what you told and it works I will let you know if it is complete. Quote Share this post Link to post Share on other sites More sharing options...
0 Kinom Posted December 8, 2009 Report post Posted December 8, 2009 Ok hire it comes. What I have done is: Copy past the USMT folder from the Program files of a XP computer to a server share and created a package pointed to the X86 folder and distributed to the DPs (No program). You can use this also C:\Program Files\Windows AIK\Tools\USMT I added into the task sequence and specify the files just like you told me. It is strange because on my virtual environment I dont have to do these steps, pointing to the X86 file and add the files. Migrate XP to Win7 no problem Now I am testing to migrate a vista to win7 but I have to configure the MigUser.xml and I dont know what to change Quote Share this post Link to post Share on other sites More sharing options...
Ho all,
