su5577
issue with PXE not picking up DHCP?
Recently setup SCCM 2012R2 setup and captured reference image of windows 7.
When trying to PXE boot and try to deploy this image, its not picking up the WDS server? It just comes up with message, DHCP failed.
Where can I start to find out what is causing this issue?
restarted/reinstalled WDS services multiple times and no luck.
yes, DCHP and DNS server is configured inside server 2012R2.
Boundaries and Boundary groups are all setup.
I was able to capture the reference image successfully and added to Distribution Point. -It says looking for PXE and it fails. I dont get the option to press F12 to PXE boot. I dont have any firewalls or proxy setup either.
have you configured a dhcp server ?
so what exactly do you see when you pxe boot, can you take a screenshot of the error, is it happening on only one system, is there a network cable attached ?
This can be especially frustrating if you don't have control of your network/switching gear or DHCP. I've had many a times where we do a refresh of network/server equipment and for whatever reason the IP Helper address on the switches was added incorrectly. Glad you got it worked out.
