spgsitsupport Posted February 3, 2017 Report post Posted February 3, 2017 Two Dell PC (Latitude & Precision) Same task sequence assigned to both. Latitude runs fine, TS runs & finished with success On Precision I get an instant error (before even TS starts running) Found location: http://SCCM1.domain.local/SMS_DP_SMSPKG$/SP1000D6 Found location: http://SCCM1.domain.local/NOCERT_SMS_DP_SMSPKG$/SP1000D6 Local=0 Processing 1 locations. Not processing remote location: Flags: 01000000 URLs : 1 SMB : MCS : No static content server. (LocationsList.size() + slistHttpPaths.size() + slistSMBPaths.size()) > 0, HRESULT=80040102 (e:\qfe\nts\sms\framework\tscore\resolvesource.cpp,2427) FALSE, HRESULT=80040102 (e:\qfe\nts\sms\framework\tscore\tspolicy.cpp,1971) Content location request for SP1000D6:9 failed. (Code 0x80040102) hr, HRESULT=80040102 (e:\qfe\nts\sms\framework\tscore\tspolicy.cpp,2757) Failed to resolve PackageID=SP1000D6 (*iTSReference)->Resolve( pTSPolicyManager, dwResolveFlags ), HRESULT=80040102 (e:\qfe\nts\sms\framework\tscore\tspolicy.cpp,3575) m_pSelectedTaskSequence->Resolve( m_pPolicyManager, TS::Policy::TaskSequence::ResolvePolicy | TS::Policy::TaskSequence::ResolveSource, fpCallbackProc, pv, hCancelEvent), HRESULT=80040102 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,1469) Failed to resolve selected task sequence dependencies. Code(0x80040102) ResolveAndExecuteSelectedTaskSequence( 0, 0, 0 ), HRESULT=80040102 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2438) RunWizardForPXE(), HRESULT=80040102 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2739) oTSMediaWizardControl.Run( sMediaRoot, true, sTSLaunchMode ), HRESULT=80040102 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,1098) Execute( eExecutionEnv, sConfigPath, sTSXMLFile, uBootCount, &uExitCode ), HRESULT=80040102 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,1246) Exiting with return code 0x80040102 Execution complete. hMap != 0, HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentscope.cpp,493) m_pGlobalScope->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,335) this->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,553) ::RegOpenKeyExW (HKEY_LOCAL_MACHINE, sKey.c_str(), 0, KEY_READ, &hSubKey), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\utils.cpp,810) RegOpenKeyExW is unsuccessful for Software\Microsoft\SMS\Task Sequence GetTsRegValue() is unsuccessful. 0x80070002. End program: Finalizing logging from process 436 Finalizing logs to root of first available drive Successfully finalized logs to C:\SMSTSLog Cleaning up task sequencing logging configuration. TS::Environment::SharedEnvironment.isInitialized() == true, HRESULT=80004005 (e:\nts_sccm_release\sms\framework\tscore\tslogging.cpp,694) TS environment is not initialized Surely that makes no sense? Seb Quote Share this post Link to post Share on other sites More sharing options...
Rocket Man Posted February 4, 2017 Report post Posted February 4, 2017 Is the Precision system within the same boundary/network as Latitude? Have you tried re-distributing the package SP1000D6 which is currently on version 9? You could also try and re-create the TS. https://social.technet.microsoft.com/Forums/en-US/5065a37f-99e3-4017-8832-a3f27d5a735f/content-location-request-for-xxxxxxx-failed-code-0x80040102?forum=configmanagerosd Quote Share this post Link to post Share on other sites More sharing options...
spgsitsupport Posted February 23, 2017 Report post Posted February 23, 2017 Network driver makes no difference (connectivity is OK in either case) Boundry/network not an issue - both on same switch TS re-create is not an option (I have tens of models using the same TS) and never had same error failure Quote Share this post Link to post Share on other sites More sharing options...
dariuszs Posted March 6, 2018 Report post Posted March 6, 2018 I am having similar issue, did you ever get to the bottom of this? I checked the boundaries, redistributed package and re-created TS with no effect. Quote Share this post Link to post Share on other sites More sharing options...
viknesh Posted September 14, 2018 Report post Posted September 14, 2018 I am having the same issue with Lenovo . Anyone have found any solution to this or any suggestion? Quote Share this post Link to post Share on other sites More sharing options...
