Kinom
Hardlink moves from C drive to D drive
Hi All
Can someone help me?
I managed to do the USMT capture.
I check on the C drive if the hardklink is there and all the files, it is.
Now when the task sequence reboots the computer it does something strange.
De hardlink on the C drive is gone and I see the hardlink on the D drive but I dont see the files.
It deploys Win7 and if it starts with the restore of the user data I receave an error (0x8007001c).
Is it possible to configure that the hardlink has to stay on the C drive?
Logs from the SCCM Console:
dstate.log" /progress:"C:\Windows\system32\CCM\Logs\SMSTSLog\loadstateprogress.log" /i:"D:\_SMSTaskSequence\Packages\F010013C\x86\MigApp.xml" /i:"D:\_SMSTaskSequence\Packages\F010013C\x86\MigDocs.xml" /i:"D:\_SMSTaskSequence\Packages\F010013C\x86\MigUserxml" /nocompress /hardlink Connection request for "D:\_SMSTaskSequence\UserState" Path is not a UNC Path. Trying it as a local path. Succeeded loading resource DLL 'C:\Windows\system32\CCM\1033\TSRES.DLL' Executing command line: "D:\_SMSTaskSequence\Packages\F010013C\loadstate.exe" "D:\_SMSTaskSequence\UserState" /c /lae /lac:*** /l:"C:\Windows\system32\CCM\Logs\SMSTSLog\loadstate.log" /progress:"C:\Windows\system32\CCM\Logs\SMSTSLog\loadstateprogress.log" /i:"D:\_SMSTaskSequence\Packages\F010013C\86\MigApp.xml" /i:"D:\_SMSTaskSequence\Packages\F010013C\x86\MigDocs.xml" /i:"D:\_SMSTaskSequence\Packages\F010013C\x86\MigUser.xml" /nocompress /hardlink USMT returned exit code (0x0000001c). Look USMT log file loadstate.log for detail error message.
Scanstate Log:
2009-12-10 16:51:01, Info [0x000000] USMT Started at 2009/12/10:16:51:01.661
2009-12-10 16:51:01, Info [0x000000] Command line: D:\_SMSTaskSequence\Packages\F010013C\scanstate.exe D:\_SMSTaskSequence\UserState /o /localonly /c /efs:copyraw /l:C:\Windows\system32\CCM\Logs\SMSTSLog\scanstate.log /progress:C:\Windows\system32\CCM\Logs\SMSTSLog\scanstateprogress.log /i:D:\_SMSTaskSequence\Packages\F010013C\MigApp.xml /i:D:\_SMSTaskSequence\Packages\F010013C\MigDocs.xml /i:D:\_SMSTaskSequence\Packages\F010013C\MigUser.xml /nocompress /hardlink
2009-12-10 16:51:01, Info [0x000000] Script file specified: D:\_SMSTaskSequence\Packages\F010013C\MigApp.xml[gle=0x00000002]
2009-12-10 16:51:01, Info [0x000000] Script file specified: D:\_SMSTaskSequence\Packages\F010013C\MigDocs.xml[gle=0x00000002]
2009-12-10 16:51:01, Info [0x000000] Script file specified: D:\_SMSTaskSequence\Packages\F010013C\MigUser.xml[gle=0x00000002]
2009-12-10 16:51:01, Info [0x000000] Starting the migration process[gle=0x00000006]
2009-12-10 16:51:02, Warning [0x080462] CListSysFileFilter::BuildTree: could not create FileList object for D:\_SMSTaskSequence\Packages\F010013C\SFLISTLH.DAT: Win32Exception: \\?\D:\_SMSTaskSequence\Packages\F010013C\SFLISTLH.DAT: The system cannot find the file specified. [0x00000002] __thiscall UnBCL::FileStream::FileStream(const class UnBCL::String *,enum UnBCL::FileMode,enum UnBCL::FileAccess,enum UnBCL::FileShare,unsigned long)
2009-12-10 16:51:02, Warning [0x0803ec] Registry location HKCU\Software\Microsoft\Windows Live Mail [store Root] is considered invalid in the current context
2009-12-10 16:51:02, Warning [0x0803ec] Registry location HKCU\Software\Microsoft\Works\9.0\Common\Templates [TemplateDirectory] is considered invalid in the current context
2009-12-10 16:51:09, Info [0x000000] System information:
Computer name: LPT00223
Machine SID: S-1-5-21-2548410259-1414263244-2658524999
OS version: 6.0.6002.Service Pack 2
Language: en-US
Architecture: 32-bit
Drives:
C: Type: Fixed, Bus type: ATA, Hotplug: No
D: Type: Fixed, Bus type: ATA, Hotplug: No
E: Type: CD/DVD
Users:
FCSNTDOMAIN\xxx_INSTALL, administrator: No, interactive: Yes, logged on: No, has profile: Yes
FCSNTDOMAIN\xxxxxx, administrator: No, interactive: Yes, logged on: No, has profile: Yes
LPT00223\xxx, administrator: Yes, interactive: Yes, logged on: No, has profile: Yes
LPT00223\Guest, administrator: No, interactive: Yes, logged on: No, has profile: No
LPT00223\Administrator, administrator: Yes, interactive: Yes, logged on: No, has profile: No
2009-12-10 16:51:09, Info [0x000000] Processing the settings store[gle=0x00000006]
2009-12-10 16:51:09, Info [0x000000] Examining the system to discover the migration units
[gle=0x00000006]
2009-12-10 16:51:20, Warning [0x0803ec] Registry location HKCU\Software\Microsoft\Windows Live Mail [store Root] is considered invalid in the current context
2009-12-10 16:51:20, Warning [0x0803ec] Registry location HKCU\Software\Microsoft\Works\9.0\Common\Templates [TemplateDirectory] is considered invalid in the current context
2009-12-10 16:51:21, Info [0x000000] Selecting migration units
[gle=0x00000006]
2009-12-10 16:51:21, Info [0x000000] Estimating total file size for the progress log[gle=0x00000006]
2009-12-10 16:51:23, Warning [0x0803ec] Registry location HKCU\Software\Microsoft\Windows Live Mail [store Root] is considered invalid in the current context
2009-12-10 16:51:23, Warning [0x0803ec] Registry location HKCU\Software\Microsoft\Works\9.0\Common\Templates [TemplateDirectory] is considered invalid in the current context
2009-12-10 16:51:37, Info [0x000000] Gathering data
[gle=0x00000006]
2009-12-10 16:51:40, Error [0x0808fe] Plugin {0db12ccb-7cfd-46b6-b4d1-daa6ff0fbcf7}: CscMig: CscMigrationPlugin::raw_Gather(693):Fatal error gather information from CSC cache, status = 0xc0000035
2009-12-10 16:51:40, Error [0x080389] Failure while calling IDiscovery->Gather for Plugin={ServerPath="%SYSTEM32%\CscMig.dll", CLSID={0db12ccb-7cfd-46b6-b4d1-daa6ff0fbcf7}, ThreadingModel=Apartment}. Error: 0xD0000035
2009-12-10 16:51:56, Error [0x0808fe] Plugin {0db12ccb-7cfd-46b6-b4d1-daa6ff0fbcf7}: CscMig: CscMigrationPlugin::raw_Gather(693):Fatal error gather information from CSC cache, status = 0xc0000035
2009-12-10 16:51:56, Error [0x080389] Failure while calling IDiscovery->Gather for Plugin={ServerPath="%SYSTEM32%\CscMig.dll", CLSID={0db12ccb-7cfd-46b6-b4d1-daa6ff0fbcf7}, ThreadingModel=Apartment}. Error: 0xD0000035
2009-12-10 16:51:59, Warning [0x0803ec] Registry location HKCU\Software\Microsoft\Windows Live Mail [store Root] is considered invalid in the current context
2009-12-10 16:51:59, Warning [0x0803ec] Registry location HKCU\Software\Microsoft\Works\9.0\Common\Templates [TemplateDirectory] is considered invalid in the current context
2009-12-10 16:52:31, Info [0x000000] Success.[gle=0x00000006]
2009-12-10 16:52:31, Info [0x000000] USMT Completed at 2009/12/10:16:52:31.933[gle=0x00000006]
3 answers to this question
Task sequence:
1 Capture network settings
Migrate Domain and workgroup membership (selected)
Migrate Network adapter configuration (selected)
2 capture Windows settings
Migrate computer name (selected)
Migrate registered user and organization names (selected)
Migrate timezone (selected)
3 OSDStateStorePath
Value --> %_SMSTSUserStatePath%
4 OSDMigrateAdditionalCaptureOptions
Value --> /nocompress /hardlink
5 Capture User State
Customize how user profiles are captured
Files: MigApp.xml, MigDocs.xml and MigUser.xml
6 Restart in winPE
7 Apply operating system
8 Apply windows settings
9 Join domain
10 Apply device drivers
11 setup configMgr
12 OSDMigrateAdditionalRestoreOptions
13 Restore User State
Restore local computer user profile (selected)
Set a password
Continue if some files cannot be restored (selected)
The USMT package is pointed to the X86 folder
The computer is an existing Vista with 2 partitions C and D drive.
