FEJustinTH
SCCM Filling up on space on SQL and main drive
I am having an issue where it is filling up the main data drive with hash files. The hash files are the same size as the WIM files we use. They are in the root drive of the FileLib directory, and they all have different names but are the same size which correlate perfectly with the WIM file sizes. One has 7 copies (8.6 GB each), another 24 (5 GB each), and the last one has 18 (4.8 GB each).
Then on the SQL drive there is a FileLib that has the same hash files with the same sizes, they are being duplicated there but not as many. I am not sure which log file is required to look at this issue, I was guessing that it was SMSProv but I will wait for the correct requested one.
Our Operating System Images files were set on a schedule to update and distribute and when they tried to distribute after a update on the 19th they failed because the hash files filled the drives. I tried removing one of them from a DP and redistributing it but it does not even try to do it (does not show it In Progress).
