rsakai2
DCIS 4.2 Installation Issues
I'm trying to install DCIS 4.2 on my computer with System Center Configuration Manager 2012 R2 console installed. The installer runs until it gets to "Importing Custom Dell Reboot Package" and then goes right into "Rolling Back Option". I've tried this on a system with the SCCM Console installed fresh in case there was an issue with the original system's install with the same result. Has anyone run across this? Do I need to upgrade my DCIS version the actual management point server first?
Thanks in advance.
Ryan
