danhart300 Posted March 15, 2017 Report post Posted March 15, 2017 Hi, As stated in the title. It gets about one quarter of the way through applying the operating system and just stops without an error code. I've attached the SMSTS log. I will continue to troubleshoot this. Any help will be greatly appreciated. Thanks. smsts.log Quote Share this post Link to post Share on other sites More sharing options...
8of9 Posted March 15, 2017 Report post Posted March 15, 2017 "Cannot read source file C:\_smstasksequence\packages\p0100041\win7_ent_x64_base.wim, Win32 Error = 1117" Do you have any other .wim images that apply okay? And is the content up-to-date on the Distribution Point? Quote Share this post Link to post Share on other sites More sharing options...
danhart300 Posted March 15, 2017 Report post Posted March 15, 2017 I have tried the same image on other machines and it is working fine (very slowly though). And all content is definitely up to date on the DP. Quote Share this post Link to post Share on other sites More sharing options...
danhart300 Posted March 16, 2017 Report post Posted March 16, 2017 It seems to be hanging on the HASH Check. Any thoughts? Attached another smsts log smsts.log Quote Share this post Link to post Share on other sites More sharing options...
Rocket Man Posted March 17, 2017 Report post Posted March 17, 2017 Seems like a HDD issue i/o error is it just a particular system or is it multiple systems? if one system have you tried new HDD - or use diskpart to delete and create new partitions Quote Share this post Link to post Share on other sites More sharing options...
danhart300 Posted March 17, 2017 Report post Posted March 17, 2017 On 3/17/2017 at 12:44 AM, Rocket Man said: Seems like a HDD issue i/o error is it just a particular system or is it multiple systems? if one system have you tried new HDD - or use diskpart to delete and create new partitions Expand It is just one system. I will try another HDD and see if error occurs. Quote Share this post Link to post Share on other sites More sharing options...
danhart300 Posted March 17, 2017 Report post Posted March 17, 2017 It was the HDD. The HDD isn't showing any form of health errors, unsure of what could be the cause. Thanks for the help though! Quote Share this post Link to post Share on other sites More sharing options...
Rocket Man Posted March 17, 2017 Report post Posted March 17, 2017 Maybe diskpart manually and clean disk etc.. and try again with CM task sequence! 1 Quote Share this post Link to post Share on other sites More sharing options...
