Stino
Xp capture problems
Hey,
I'm trying to create a capture-image of a sysprepped XP computer. The catch is that it is a virtual machine...
Installed drivers, updates and everything else... works fine.
Then I sysprepped it with following options: Pnp, regenerate SID and resealed.
Created a boot.wim and injected the vmware nic-drivers and after that i created the capture-image from this modified boot.wim.
I can boot up to the WDS-capturewizard and ten I need to select a volume to capture.
Problem is that i can not select a single drive!
Updated the sysprep to latest version with no succes, looked for some logfiles in windows/panther to delete but they weren't there.
I use a W2K8 dedicated WDS server. My domaincontroller and DHCP are on another W2K3-server.
Used the Windows Vista business DVD to upload the boot.wim file that i modified with the vmware nic-drivers
Does anybody have an idea?
Using sysprep for more than 4 years now and i do not haveany difficulties what so ever with this...
What do i do wrong?
Thanx in advance
Stin
