Guru
Distribution point OS migration Packages are missing
We have a remote distribution point upgraded with OS 2012.Before the upgradation we removed the DP role and the site system from the server.Since the server is VM we detached the drive which contains  sccmcontentlib$ folder.After the OS installation attached the same drive with same drive letter and folder structure.
After the re-installation of new DP with same IP,hostname - remoteinstall folder has created on another drive and we couldn't find any packages distributed on the server from the console.
How do I get all those packages without re-distributing each package ?
Thanks Guru !
