EGGLAS
Refresh Scenario and Bitlocker WinPE
I'm having trobule with refreshing Windows 10 computers from WinPE. We need to upgrade BIOS before BIOS Conversion step in CM1610 and set BIOS settings. When reinstalling an computer it fails at staging Boot image.
I have tried to size up the disk so it can hold larger WinPE Boot image but it does not work.
2048 MB Recovery
1024 MB EFI
128 MB MSR
100% OSD
If I disable the step for BIOS Upgrade and Configure I can reinstall an computer without problems.
<![LOG[Process completed with exit code 1]LOG]!><time="14:10:08.323-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="commandline.cpp:1124">
<![LOG[TSUEFIDrive: ]LOG]!><time="14:10:08.323-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="bootimage.cpp:774">
<![LOG[Staging boot image CM1000AA]LOG]!><time="14:10:08.323-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="bootimage.cpp:781">
<![LOG[Mounting \Device\HarddiskVolume6 at Z:]LOG]!><time="14:10:08.338-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="mountpoint.cpp:49">
<![LOG[Unmounting volume Z:\]LOG]!><time="14:10:08.338-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="mountpoint.cpp:104">
<![LOG[0, HRESULT=80004005 (e:\nts_sccm_release\sms\framework\tscore\encryptablevolume.cpp,437)]LOG]!><time="14:10:08.354-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="encryptablevolume.cpp:437">
<![LOG[Checking to see if the data path is on a bootable volume]LOG]!><time="14:10:08.354-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="bootimage.cpp:1104">
<![LOG[ Volume S:\ is not NTFS]LOG]!><time="14:10:09.249-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="bootimage.cpp:362">
<![LOG[Searching for a volume to stage the boot image]LOG]!><time="14:10:09.249-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="bootimage.cpp:1128">
<![LOG[ Volume S:\ is not NTFS]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="bootimage.cpp:362">
<![LOG[ Volume X:\ is not on a fixed disk]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="bootimage.cpp:342">
<![LOG[BootImage::FindBootableVolume( NULL, sPath), HRESULT=80070490 (e:\nts_sccm_release\sms\framework\tscore\bootimage.cpp,1135)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="bootimage.cpp:1135">
<![LOG[Unable to find a volume that is suitable for staging the boot image.
Element not found. (Error: 80070490; Source: Windows)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="3" thread="1320" file="bootimage.cpp:1135">
<![LOG[BootImage::PrepareForStaging(sLocalDataPath), HRESULT=80070490 (e:\nts_sccm_release\sms\framework\tscore\bootimage.cpp,783)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="bootimage.cpp:783">
<![LOG[Failed to validate for boot image staging]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="3" thread="1320" file="bootimage.cpp:783">
<![LOG[StageBootImage() failed. 0x80070490.]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="3" thread="1320" file="bootimage.cpp:889">
<![LOG[TS::Boot::BootImage::StageBootImage(sBootImageID, StageBootImageProgressCallback, (LPVOID) m_sStageBootImageMessage.c_str()), HRESULT=80070490 (e:\nts_sccm_release\sms\client\tasksequence\executionengine\engine.cxx,972)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="engine.cxx:972">
<![LOG[Failed to stage a boot image CM1000AA.
Element not found. (Error: 80070490; Source: Windows)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="3" thread="1320" file="engine.cxx:972">
<![LOG[Failed to reboot the system. Error 0x80070490)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="3" thread="1320" file="engine.cxx:1140">
<![LOG[RebootSystem(pwszRebootMessage, dwRebootTimeout, dwRebootReason, bRebootWinPE), HRESULT=80070490 (e:\nts_sccm_release\sms\client\tasksequence\executionengine\engine.cxx,622)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="engine.cxx:622">
<![LOG[Failed to initialize a system reboot.
Element not found. (Error: 80070490; Source: Windows)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="3" thread="1320" file="engine.cxx:622">
<![LOG[CheckForRebootRequest(&bRebootInitiated), HRESULT=80070490 (e:\nts_sccm_release\sms\client\tasksequence\executionengine\engine.cxx,310)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="engine.cxx:310">
<![LOG[Fatal error is returned in check for reboot request of the action (Restart Computer).
Element not found. (Error: 80070490; Source: Windows)]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="3" thread="1320" file="engine.cxx:310">
<![LOG[An error (0x80070490) is encountered in execution of the task sequence]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="3" thread="1320" file="engine.cxx:390">
<![LOG[MP server http://LKSRVSCCM03.res.ludvika.intra. Ports 80,443. CRL=false.]LOG]!><time="14:10:09.264-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="utils.cpp:6255">
<![LOG[Setting authenticator]LOG]!><time="14:10:09.280-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="utils.cpp:6277">
<![LOG[Set authenticator in transport]LOG]!><time="14:10:09.280-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="libsmsmessaging.cpp:7958">
<![LOG[Sending StatusMessage]LOG]!><time="14:10:09.296-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="libsmsmessaging.cpp:4114">
<![LOG[Setting message signatures.]LOG]!><time="14:10:09.296-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="libsmsmessaging.cpp:1383">
<![LOG[Setting the authenticator.]LOG]!><time="14:10:09.296-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="libsmsmessaging.cpp:1413">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: LKSRVSCCM03.res.ludvika.intra:80  CCM_POST /ccm_system/request]LOG]!><time="14:10:09.296-120" date="05-10-2017" component="TSManager" context="" type="1" thread="1320" file="libsmsmessaging.cpp:8828">
<![LOG[Request was successful.]LOG]!><time="14:10:09.327-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="libsmsmessaging.cpp:9163">
<![LOG[Executing command line: X:\WINDOWS\system32\cmd.exe /k]LOG]!><time="14:10:21.451-120" date="05-10-2017" component="TSBootShell" context="" type="1" thread="1016" file="bootshell.cpp:1011">
<![LOG[The command completed successfully.]LOG]!><time="14:10:21.455-120" date="05-10-2017" component="TSBootShell" context="" type="1" thread="1016" file="bootshell.cpp:1093">
<![LOG[Successfully launched command shell.]LOG]!><time="14:10:21.455-120" date="05-10-2017" component="TSBootShell" context="" type="1" thread="1016" file="bootshell.cpp:444">
<![LOG[m_TSEngine.Execute(& m_eExecutionResult), HRESULT=80070490 (e:\nts_sccm_release\sms\client\tasksequence\tsmanager\tsmanager.cpp,1250)]LOG]!><time="14:25:10.554-120" date="05-10-2017" component="TSManager" context="" type="0" thread="1320" file="tsmanager.cpp:1250">
Thanks in advance,
EGGLAS
